NOS 1960-76 Ford Truck 352/360/390 Main Bolts SOLD OUT !!!!!!!!!!!!!!!
Private parties only. No eBay/Craigslist listings.
FORD-F250-4x4-1972
Post by FORD-F250-4x4-1972 »
For Sale NOS 1960-76 Ford Truck F100-250-350 F-Series Trucks FE Big Block Main Bearing Bolts Fits all 332/352/360/390/406/410/427/428-CJ-SCJ Engines Ford Part Number # C1AE-6345-B and i have 9 bolts in stock and my asking price $25.00 plus Priority Small Flat Rate Mini Mailing box $6.10 With Confirmation Tracking number and if you have any questions please PM me and i do have more NOS Ford FE Parts in stock 16) Connecting rod nuts $1.50 each = $24.00 & 12) Cylinder Head dowels $1.50 each =$18.00 & 11) Camshaft dowels $3.50 each & 2) Camshaft Thrust Plates $18.00 each & 12) Phillips head screws $3.50 each for Camshaft thrust plate & (2) Types of Crankshaft Keys $5.00 each 1) Motorcraft Dist hold down clamp $20.00 & 2) Crankshaft Spacer Sleeve fits in timing chain cover seal $75.00 each 1) Water pump 2 groove pulley $20.00 & 16) Cylinder head oil valve seals $2.00 each & 2) oil pan gasket drain plugs $1.50 each & 2) oil pan drain plug bolts $5.00 each Thank you
Last edited by FORD-F250-4x4-1972 on Thu Feb 11, 2016 1:27 pm, edited 1 time in total.
FORD-F250-4x4-1972
Re: NOS 1960-76 Ford Truck 352/360/390 Main Bearing Bolts
I Still have theses NOS FORD FE Big Block Main bearing bolts and other parts in stock For-Sale and please make me an offer Thank you
FORD-F250-4x4-1972
:fr: :thup:
