Can somebody ID this trans?
eskelton
Post by eskelton »
:? Ive got a transmission ive been told that could possibly be a ford 400. How do i id it if it is? I have the numbers off the side of the transmission ( Driver side of it ). Can someone tell me by these numbers what it may be? :?
72 SWB F100 306 3 Speed
72 SWB F100 302 C6
70 LWB F100 300 C4
67 LWB F100 429 C6
Donnie
Re: Can somebody ID this trans?
Post by Donnie »
Hi, D4 only means that part was introduced into the line in that year....D=7 4 is the first year of production. To the best of my knowledge Ford didn't have a model 400.........General Motors did.........Show us a complete photo & we can tell you what you have............Donnie
1972hiboy
Post by 1972hiboy »
looks like it may be a fmx trans for a ford 400m motor.
Rich
Dont eat yellow snow.....
Donnie
Post by Donnie »
:yt: I think that HIboy is correct....looks like a center support bolt showing above the case #'s....donnie
eskelton
Post by eskelton »
Donnie wrote:Hi, D4 only means that part was introduced into the line in that year....D=7 4 is the first year of production. To the best of my knowledge Ford didn't have a model 400.........General Motors did.........Show us a complete photo & we can tell you what you have............Donnie
I know gm had a 400, i was told ford did as well. But im new to the ford world so im still learning up. Let me find another picture of it and post it for you guys!
72 SWB F100 302 C6
70 LWB F100 300 C4
67 LWB F100 429 C6
eskelton
Post by eskelton »
1972hiboy wrote:looks like it may be a fmx trans for a ford 400m motor.
Whats a fmx trans?? Is it a good trans to build or is it junk to just toss?
Here's the other pictures i have of it.
72 SWB F100 302 C6
70 LWB F100 300 C4
67 LWB F100 429 C6
bluef250
Post by bluef250 »
I think there are 3 bell housings for the C6 and several variations.
The FE, Series 335/385 (351m, 400, 429, and 460), and the small block (inline, 351c, 351w, 302, 289). The 351m and 400 were a variation of the 351c. Do an internet search for more details.
The cruise-a-matic to AOD were continuous development of the same design. Each was built for a specific purpose, some weaker, some stronger.
The (mx-hd in 1967) FMX can be rebuilt but upgrades are limited. The C6 is better for modifications. It all depends what you are trying to do and your budget.
http://www.fordification.com/tech/transID-auto.htm The Fordification site does a good job of summarizing the transmissions.
eskelton
Post by eskelton »
bluef250 wrote:I think there are 3 bell housings for the C6 and several variations.
Thanks for the info. Ill look em up and see what i can't find out. I am just debating on whether or not to take my truck and convert it to a auto truck or if i should dump the ole 3 speed and upgrade to a 4 speed
72 SWB F100 302 C6
70 LWB F100 300 C4
67 LWB F100 429 C6
1972hiboy
Post by 1972hiboy »
another thing you can try is pull the pan and get the filter or screen number and ask the auto parts store what application it fits. kinda like reverse dissection....should be able to give you a application at least.
Rich
Donnie
Post by Donnie »
There should be a tag attached to one of the extension bolts....that info will narrow down your search...they are not a difficult trans to build, they just use a diff. geartrain that the C4 & C6......That trans has been in use since the 1950's, various version's of it are still using the Ravigneaux complex gear train...harder to repair than the C4 & C6 which use a Simpson gear train...E.G.. 2 separate planetary gear sets..on those units you can replace either 1 or the other planetary if 1 is faulty..where with the French gear set things get more complicated....Not a bad trans, but it would be my 3rd choice of the 3 speed's......donnie :2cents:
cep62
Post by cep62 »
It looks like a bolt on bellhousing. I know C4s had them ,did the FMX too ?
Donnie
Post by Donnie »
Yes, the Iron case units actually bolted from the rear, where as the C4 bolted from inside the bell......Donnie
