4th starter installed today.
1st one was DOA, never got the truck started
2nd worked a little while then started failing
3rd was DOA on install, started the truck a couple of times.
4th seems to be working.
Since is still had all of them in my possession i did a little comparison.
1 looked fine on the out side minus the made in china stamp.
2 and 3 both had gaps/separations...i just tried to explain what area but when re reading it it confused me....so take my words they both had visible question marks.
4 looks fine.
My hope is that it is from using grind wheel on the first three. since it would make the starter vibrate...maybe that broke something inside. The fourth one i used a hand grinder so the vibration was there instead of in the starter. Or maybe the 4BT is just rattling them apart.
Anyway also worked on the transfercase shift linkage...which is now resulting in having to bend the transmissions shifter, so that the two will clear each other.
Anyway will see what happens tomorrow....between the wife coming home and going on a damage control elk hunt...that i have two tags to fill.
