The cab is loose and sitting on the back of the frame...that's the very back end of the frame.Fordnatic wrote:Is your gas tank really right behind the cab, or is that an illusion? How will you do exhaust/ driveline, etc. ?
Ford f100 1970 resto. Nearly done!
- F100builder
Re: Ford f100 1970 resto after crash
Patrick
![Image](http://i264.photobucket.com/albums/ii183/F100builder/1969%20F100/P3220011-1.jpg)
![Image](http://i264.photobucket.com/albums/ii183/F100builder/CAXW6TDZ-1.jpg)
![Image](http://i264.photobucket.com/albums/ii183/F100builder/Copyofscan0019-1.jpg)
![Image](http://i264.photobucket.com/albums/ii183/F100builder/Copyofscan-1.jpg)
'56 F100; Must.II IFS, 351W bored & stroked to 395c.i. 470hp/483ft-lbs., AOD, 4-link coilover 9" w/ 3.89's
'69 F100; 390, C6, Dana 60 w/ 4.10's
'70 F100; 'new' and latest project soon to have a built 390/C6 and 3.50 gears
To see more of my F100's: http://www.cardomain.com/id/lowfat56
I thought that might be the case...
55F100
55F100
Yup f100builder is right, i was test fitting it on the frame and just let it there somewhere to save some space!
Tomorrow it's time to paint the leaf springs, put it back together and press the new bushings in there![Smile :)](./images/smilies/icon_smile.gif)
Ford f100 '70 302
Audi S6 4.0 tfsi
BMW 525i '90 Turbo (project 500rwhp)
Full resto:
http://fordification.com/forum/viewtopi ... &start=135
Audi S6 4.0 tfsi
Full resto:
![Image](http://i897.photobucket.com/albums/ac178/jurrien87/IMG_8929_zps1acf226c.jpg)
![Image](http://i897.photobucket.com/albums/ac178/jurrien87/IMG_8934_zps9aa89a55.jpg)
![Image](http://i897.photobucket.com/albums/ac178/jurrien87/IMG_8945_zpsa2afe646.jpg)
![Image](http://i897.photobucket.com/albums/ac178/jurrien87/IMG_8955_zps71a73a7f.jpg)
![Image](http://i897.photobucket.com/albums/ac178/jurrien87/IMG_8937_zpsbebfe7c5.jpg)
![Image](http://i897.photobucket.com/albums/ac178/jurrien87/IMG_8947_zps15a9c6c2.jpg)
Ford f100 '70 302
Audi S6 4.0 tfsi
Full resto:
Audi S6 4.0 tfsi
Full resto:
Rear end looks great and a cool idea on that trans x/m!
Great job what your doing there takes a lot of dedication.
Just a tip that was given to me when I first started welding in panels for rust repair or to shave holes like your stake holes in the bed rails. Cut your filler pieces smaller than what you're doing. Leave a gap around all sides don't cut them tight so they are touching or so close that you can't get weld in to the gaps. The pics showing the panel after you've ground off the surface weld you can see the line around the filler panel. After grinding it should look like one piece of sheet metal.
Looking forward to following your progress.
HELP! Looking For Horn Button Guts
Mike
'67 F100
Mike
'67 F100
i don't know why i did it like that, i wasn't thinking because i know i need a small gap between the welds...
later on i bought clips for the gap, went a lot better!
thanks for the tip!
chassis is finished, i am working in south america at the moment, so the sandblasting and paint has to wait.
![Image](http://s897.photobucket.com/user/jurrien87/library/#/user/jurrien87/library/?sort=2&page=1&_suid=138128847267104736227104334197)
![Image](http://i1180.photobucket.com/albums/x418/jurrien9/F885F3C4-6FAD-423D-AB0E-266DD9BE650C-12444-00001182D66AE5FD_zps67a97b1a.jpg)
![Image](http://i1180.photobucket.com/albums/x418/jurrien9/6F06D441-8BA7-48C9-BC92-374E48E8F76F-12444-00001182E5064450_zps13caf942.jpg)
putting some wait on the axle for the angle of the engine
![Image](http://i1180.photobucket.com/albums/x418/jurrien9/A77B3F99-F8CD-4D96-A1D9-651A68C02036-12444-00001182F010CEE1_zps560b3d04.jpg)
![Image](http://i1180.photobucket.com/albums/x418/jurrien9/13D5F972-405B-4D37-972B-53C5BF4F5A15-12444-00001182F9D000C2_zps3b43e21a.jpg)
![Image](http://i1180.photobucket.com/albums/x418/jurrien9/29AF5E5F-E0C9-47D9-BB0D-2DB478769245-12444-0000118303C62623_zpsefbc78f4.jpg)
thanks for the tip!
Ford f100 '70 302
Audi S6 4.0 tfsi
Full resto:
Audi S6 4.0 tfsi
Full resto:
Looking good.
Those panel clamps are great, right. I just buy the cheapy HF ones and grind them thinner because they are too thick.
Mike
'67 F100
Mike
'67 F100
![Image](http://i1180.photobucket.com/albums/x418/jurrien9/C2C9F91D-3A99-4D59-9B56-5602422A11C9-560-00000166C3C40727_zps14d4ad5b.jpg)
![Image](http://i1180.photobucket.com/albums/x418/jurrien9/5E262380-1E32-4D1B-B2D3-8A1518B51CB4-560-00000166B92958B6_zps281d714e.jpg)
black paint will be done this week to!
Ford f100 '70 302
Audi S6 4.0 tfsi
Full resto:
Audi S6 4.0 tfsi
Full resto:
I realize the rear springs are assembled the way they were taken off the truck but it looks like the overload spring is on top of the spring pack and not on the bottom of the pack like it is supposed to be. Just doesn't seem right.
1968 f100 Ranger
1972 f100 Sport Custom
1972 f250 4x4 conversion
Thanks for that, strange that is was mounted that way.
I'll go change it today!
Ford f100 '70 302
Audi S6 4.0 tfsi
Full resto:
Audi S6 4.0 tfsi
Full resto:
Ford f100 '70 302
Audi S6 4.0 tfsi
Full resto:
Audi S6 4.0 tfsi
Full resto:
- Craigerf100
cool ![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
1968 F-100 Short Bed
1967 Fairlane 500 Convertable
1967 Fairlane GT/A 289ci SOLD
My Build:
http://www.fordification.com/forum/view ... &sk=t&sd=a
My Build:
How many hours was that?
Mike
'67 F100
Mike
'67 F100
About 4/5 hours, 30 sec inbetween pictures
Ford f100 '70 302
Audi S6 4.0 tfsi
Full resto:
Audi S6 4.0 tfsi
Full resto:
