Where is the fill cap on the 9 in Ford axle? I have the fluid but I couldn't seem to find the bolt when I looked today. Its probably obvious, I'm just not sure the general area where it is at.
Thanks
Rear Axle Oil
- Subzero
Rear Axle Oil
1972 F100 Sport Custom-2WD, Aqua Blue and Wimbleton White, LWB, 302 V8 and C4 trans, P/S, P/B - under construction
Gone but not forgotten: 1968 F100 Ranger- 2WD, LWB, original rebuilt 360 V8, Autolite 2bbl carb, C6 Trans, Hedman Headers, Powermaster Racing Starter, H-Pipe and Glasspacks, P/S, P/B, A/C
Re: Rear Axle Oil
Dig through the greasy dirt next to the drive shaft yoke .
You should see a plug
with a 3/8 square in it .
clean it out and use a ratchet and extension.
Early 9 inches had the plug in the back housing so they don't have a plug in front.
