Rear end widths
SoCalExile
Rear end widths
Post by SoCalExile »
So I removed the stock sized wheels with the stock sized
tires the other day and noticed fresh rub marks on the rubber and the tubs! Knowing that the gear ratio is not stock, nor is the rest of the drivetrain and the engine, I measured the axle between the innermost flat portion of the backing plate and came out with 54". Is this correct for a stock 71 F100?
