1967-1972 F100 parts trucks
Re: 1967-1972 F100 parts trucks
Any chance you have a '67 style inside rear view mirror?
Will
Will
rmurphy wrote:I don't have any F250. I think any year should fit, if so I now I'd have one on a F100. $10 and ride. I'm tearing down a 70' now.Jtorres wrote:Do you have any suspension parts for a 67. If so and I know its a horrible description of the part.... But I need the spacer that sits between the radius arm and the lower seat for the spring. Thanks.
I think your right, if possible could you snap a pic for me. That way I could tell your for sure if it's the part I need. I'll try to look for a pic of it too. thanks man
1967 F-250
- guhfluh
Hey Ronnie! When are you coming to Cruisin The Coast? Do you have any 67-69 steel headlight doors that aren't dented or rusted through? I also will need 1967 heater control cables, bezels and knobs. I ruined my fan switch knob and heater/temp cables and bezel trying to make it all work with the new A/C kit. I'll be here until Tues night, then come back for Sat and Sun.
'67 F-250 Crew 2wd 300ci, T-170/RTS/TOD 4-speed overdrive
'96 Dodge Ram ECLB CTD
'99 Dodge Neon ACR 2dr - 10.64@130 (Sold)
'05 Infinity G35 Sedan
would you have a booster bracket for a 67 f100? The bracket that mounts the booster to the firewall?
If so how much shipped to 60655?
Thank you
Thank you
- rmurphy
you can use one off a 73-79 fitsBlueOvalDave wrote:would you have a booster bracket for a 67 f100? The bracket that mounts the booster to the firewall?
Thank you
- cold-steel22
I'm in need of a shifter for a 3-speed manual column. My original is trashed. Would you happen to have one?
1967 Ford F100 SWB project
Project Thread: http://fordification.com/forum/viewtopi ... 22&t=70519
- rmurphy
what part is it. shifter?cold-steel22 wrote:I'm in need of a shifter for a 3-speed manual column. My original is trashed. Would you happen to have one?
looking for the secondary gas tank(under the truck) for my 69 camper special
thanx
thanx
- rmurphy
I have the ones that go on each side of the fender wells, from the tire to the cab. Take $75 and shipping for them. they are made of fiberglass.denis62 wrote:looking for the secondary gas tank(under the truck) for my 69 camper special
thanx
pics ?
do they have senders?
I am interested
I am interested
- abyars111
Do you have any 390 fender emblems?
Anthony
1970 F250 Crew Cab 2wd 390/2v short bed
2004 Eddie Bauer Expedition
1955 Chevy 210 4dr Sedan
Do you have a good cab for a 68 ?
- rmurphy
don't have senders in themdenis62 wrote:pics ?
I am interested
- rmurphy
nopeabyars111 wrote:Do you have any 390 fender emblems?
- rmurphy
ST68RANGER wrote:Do you have a good cab for a 68 ?
nope
