I spent the rest of the day tinkering in the engine bay and with the nose metal. As you can see in the pics we made some decent progress. We spent a lot of time looking for hardware and making shopping lists for our next junk yard trip. Mostly small screws and body bolts were missing. The paint turned out pretty rough. I didn't spend enough time sanding the old primer and my paint had thickened since I used it last so the paint rolled on heavy. Of course the cab needs polished as well. I figure I'll run it like this and work out the bugs before paying someone to strip and paint it correctly.
I still need to reinforce the bottom valance panel and I need another center radiator bar as I lost two of them that were floating around the shed. Everything still clears the inter cooler by at least 1/4" so I don't want anything moving around up front. The truck is starting from the key and still isn't charging. The old regulator was bad and draining the battery. I'm sure it's something dumb with the wiring or dash being half torn apart. I do have one fried wire in the dash cluster that I have no idea where it went so maybe...
More soon.
Jamie
