Torquing Ring Gear Bolts: One way to do it when you're alone
Discuss your workshop and related equipment
Madman
Post by Madman »
I though some of these tips may come in handy if you find yourself working alone, like I do most of the time! :D
2017 Ford Raptor
1970 F250 4x4
1975 Ford Bronco
Madman
Re: Torquing Ring Gear Bolts: One way to do it when you're alone
Post by Madman »
The board supports the differential, the pinion, and the wrench....the wrench bites into the board as does the pinion, it works damn good!
2017 Ford Raptor
1970 F250 4x4
1975 Ford Bronco
crazyhorse
Post by crazyhorse »
Mr Madman , that is very good tip/idea.
Thank you for taking your time to share this .
Madman
Post by Madman »
And thanks for appreciating it! :D
2017 Ford Raptor
1970 F250 4x4
1975 Ford Bronco
Mancar1
Post by Mancar1 »
:thup: 8)
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
trozei
Post by trozei »
Another good idea!
