c4 transmission kickdown.
I've owned my 1971 F100 sb for over a year with no kickdown cable. I have read posts that say there not necessary for operation. I do believe that its not necessary. But, after finally ordering one for $40 dollars and installing it today I'm glad I did!! The kickdown cable makes my 302 run like a champ! Its a nice addition to the trucks complete operation.
- hillcountryflt
Re: c4 transmission kickdown.
where did you order your kickdown cable? I am about to change from a 3 speed manual to a C4 on my 71 F100. Different engine, but interested to know your source.
2016 Explorer;
2020 F150
2016 Harley Ultra Limited
2008 Ford Mustang Deluxe V6
2016 Explorer;
2020 F150
I got it on eBay from a guy out of columbus, Georgia. The brand of the cable is RPS I believe. Just under $40.
Was it fairly straight forward to install it? I've been toying with the idea of installing one on my 302, as well. I have an edelbrock carb, and I'm not entirely sure where the kick down cable connects to..
Also, can you explain what specifically changed, in the way the truck runs/drives?
The installation was fairly easy with instructions that were provided with the product. I run a holley carberator and they come with the connection for a kickdown cable. But I believe edelbrock carbs don't have the kickdown bracket it has to be purchased separately.
The most noticeable difference after installing kickdown cable is the truck has better acceleration. The shift points are extended at wide open throttle. Its a noticeable improvement.
- hillcountryflt
There is a company called Lokar - I found them searching through Summit Racing - that markets/makes a variety of kickdown cables, transmission connection cables, etc.
2016 Explorer;
2020 F150
2016 Explorer;
2020 F150
Lokar makes good stuff from what I've read, but I'm cheap and didn't want to pay $100 dollars for a kickdown cable. I got the chepo brand and it has worked good so far and it was only $40.
I Installed a lokar kick down cable, Pretty straight Forward, I Got it off Ebay for 75.00
"I ain't as good as I once was But I'm as good once as I ever was"
https://photos.google.com/photo/AF1QipM ... mfKhMOFcFj
1971 F100 SWB 302 2WD (Work In Progress)
2010 F250 4X4 6.4 Power Stroke / lariat Black
2020 F150 4X4 3.5 Eco Boost / icon Silver
