Torques Values
Dog_River
Torques Values
Post by Dog_River »
Hello guy's,
I have an 1972 F 250 4x4 w/ a 360. I have owned this truck for 14 years now but the last 10 years it's been sitting in my barn so I pulled it out and put it in the shop. I dropped all the fluids in it and will replace them, replaced all the belts, hoses, complete tune up, rebuilt the carb, new battery cable and battery. I checked all the u joints and they look fine, brakes seem ok. I need some new exhaust which I will get install in a week or two. I will pull the front wheel bearings and check them and re pack. Oil and lube all moving parts etc.
I need the Torque values of the front and rear diff cover bolts, engine oil pan bolts etc. Seeing's how I don't have a shop manual can you guy's direct me to an online source or this information ? I also cant remember what the front and rear ends are or the transmission. I think it's identified in the VIN number ? Is this correct ??
I also put a set of Michelin XL 9:00 x 16" of her and she is sitting pretty nice now. (((old photo attached updated photo coming soon))
I tried to search this site but didn't find what I was looking for. Any help would be great !
Anything else you guy's can think of I should check out before it goes back on the back roads ?
Thanks in advance Dog_River
Busboy
Re: Torques Values
Post by Busboy »
Seriously? :lol:
1967 F-100 4x4 custom cab.
Dog_River
Re: Torques Values
Post by Dog_River »
Busboy wrote:Seriously? :lol:
What's your problem ?
1972hiboy
Re: Torques Values
Post by 1972hiboy »
Rear axle is a Dana 60 front is a dana 44 or dana 44HD ( depending on your locking hub size) Transmission is a NP435 or a t-18.
Oil pan bolts are 12ft/lbs
Dana Cover bolts 35ft/lbs
Rich
Dont eat yellow snow.....
Dog_River
Re: Torques Values
Post by Dog_River »
Thanks for your help. I looked at the tranny today and could not see any info plates so how do you tell which it is ?
Dog_River
1972hiboy wrote:Rear axle is a Dana 60 front is a dana 44 or dana 44HD ( depending on your locking hub size) Transmission is a NP435 or a t-18.
hazelnut
Re: Torques Values
Post by hazelnut »
The top cover on the NP 435 is aluminum and I think the T 18 is cast iron.
1972hiboy
Re: Torques Values
Post by 1972hiboy »
hazelnut wrote:The top cover on the NP 435 is aluminum and I think the T 18 is cast iron.
This is what I generally believe as well but I swear Ive had somebody tell me a t-18 has a aluminum cover too. they may have been mixed up but since I cant verify for fact I didnt want to state that. Also, from what I have seen, the np435 stick bends to the Right, staying to the right side of the four wheel driver shifter. The T-18 bends to the left and stays on the left side of the four wheel driver shifter. This is circumstantial though as people bend sticks to suit them all the time. But in stock form this is what ive noticed.
Edit. http://www.fordification.com/tech/transID-man.htm
Some clarification! hope this helps.
Rich
Dog_River
Re: Torques Values
Post by Dog_River »
Thanks for the help guy's I really appreciate it ! I will investigate and let you know what I find.
Dog_River
