Gear lube
19DAVE11
Gear lube
Post by 19DAVE11 »
what gear lube should I use in a 1965 f250 2wd rearend ? dana 60
carnuck
Re: Gear lube
Post by carnuck »
Semi float 5 lug pattern or full float 8 lug? I wouldn't put synthetic in without all new seals but an 80W/140 if you haul trailer/loads. GL4.
19DAVE11
Re: Gear lube
Post by 19DAVE11 »
8 lug. Not much hauling.Do I need the friction additive? Thanks
carnuck
Re: Gear lube
Post by carnuck »
Friction additive is for posi-traction devices
