RUG overdrive trans oil
johnnyUK
Post by johnnyUK »
Hi all,
I have a 1972 390 F100. It had a 1978/79 RUG 4 speed overdrive transmission fitted in the USA before I imported it to the UK.
I want to change the trans oil, but can't find a drain plug, only a top up plug, on the casing.
I also need to know what grade/type oil it needs.
Can anyone help ?
Cheers Johnny
Mancar1
Re: RUG overdrive trans oil
Post by Mancar1 »
Isn't their a drain plug on the bottom?
I believe you use 80 weight
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
