Auto trans or 4speed without granny gear
Firefighter9103
Post by Firefighter9103 »
I have a 70 f100 bump. Long bed. With a 302 v8. What would be a good auto trans or 4speed to swap too.
eggman918
Re: Auto trans or 4speed without granny gear
Post by eggman918 »
If you go manual I would consider the M5odr2 it's a nice close ratio 5 speed and 5th is OD, one drawback it would require a hydraulic clutch but a plus is there common and fairly inexpensive.look here http://www.fordification.com/tech/M5R2_5spd-swap.htm
HIO Silver
Post by HIO Silver »
... a TKO-500... five-speed.
