OT - 8" 3rd member compatibility
sargentrs
Re: OT - 8" 3rd member compatibility
Post by sargentrs »
Decided to go with the Quick Performance http://www.quickperformance.com/Ford-8- ... _p_39.html Mike is a great guy to work with and they went the extra mile to ship my differential so I would have it this weekend. A beautifully built piece and I got it with the 3.25 gear set. It was the pinion bearing as the main problem but I guess it's a good thing it went out when it did. When I pulled the passenger brake drum, 90wt poured out and the whole workings were covered in thick black oil. Shoes had disintegrated and axle seal was totally shot. The U-joints on the drive shaft were about to explode also. Only a matter of time before I'd lost the drive shaft and the brakes totally. Decided to go ahead and replace the axle bearings while I had them out. Local shop was open yesterday and pressed them off/on for me in a couple of hours. Got the chunk stabbed and axle housing seals replaced. Had to order the rear U-joint and brake hardware kit. They'll be in today about 3pm. Hopefully I'll have her back on the road tonight!
sargentrs
Post by sargentrs »
Back on the road at last! Everything seems to be working well and she really likes the 3.25 gears. Thanks to everyone for the encouragement and advice! :fr:
ultraranger
Post by ultraranger »
Glad you're back mobile again. :thup:
sargentrs
Post by sargentrs »
Thanks, Steve!
