28 spline axle interchange
idaford
Post by idaford »
Ok I have a 1969 f100 with 28 spline axles. I took them in to get new bearings pressed in while rebuilding my center section. I had planned on having them install a Eaton true trac at the same time. The shop called me and said one of my axles must have spun a bearing and I should find another axle. I tried looking at the locale junk yards and could not find any 67-72 1/2 tons. I did see a couple of 61-66 ford 1/2 tons. I was wondering if they would work? I have been looking all over the internet and cant find a answer. What other options are there?
cep62
Re: 28 spline axle interchange
Post by cep62 »
idaford wrote: 61-66 ford 1/2 tons. I was wondering if they would work?
As far as I know no , even 67s are different ,the spacing from the bearing flange to the face is different.
They will fit the housing but the brake drum will not fit properly.
idaford
Post by idaford »
From what I can tell that might be the same problem with the pre 67 too.
cep62
Post by cep62 »
idaford wrote:What other options are there
Try these guys.
http://www.moserengineering.com/axles.html
http://drdrivelineinc.com/category/axle-shafts/
idaford
Post by idaford »
Found some at a junk yard.
