Automatic Flexplate
spacecadet
Automatic Flexplate
Post by spacecadet »
I've found pretty dismal reviews for flexplates available online.
Any suggestions on where to get a good one? Im missing a tooth or a few and it's giving me hard starts once and while.
1968 360 with C6 Automatic
1968 F250 / 360 / C6
j41385
Re: Automatic Flexplate
Post by j41385 »
Any place like Napa should either have them or be able to order one.
Image Image
spacecadet
I will go that route, wasn't sure if there was a known better option.
Another question: With the flexplate off can the rear main seal be done or does that require more tear down? From what I've seen it appears to me that you need to remove the oil pan and bearing caps?
carnuck
Post by carnuck »
Oilpan comes off and rear main cap. More caps if it's a rope seal and not 2 piece neoprene.
nhbob
Post by nhbob »
Boneheaded move on my part...put my new flexplate on, trans back on, almost done. Realized I forgot to install the backer plate on the flexplate. Deal breaker???
sargentrs
Post by sargentrs »
Do you mean the plate that goes between the transmission and the engine block? Isn't that where the hole the starter bolts into is?
tnlprt
Post by tnlprt »
Yep
Tear it back apart and install the block saver plate
It correctly locates the starter
Both in depth of engagement and side to side
Ranchero50
Post by Ranchero50 »
Ditto. Consider it the penance for not paying attention to the details. The last thing I would want is dirt / trash getting up around the converter seals.
