1968 f100 power steering pulley
Schmidty
Post by Schmidty »
I'm looking for a power steering pulley for my 1968 f100. If anybody has one they would like to sell please let me know. Thanks!!
basketcase0302
Re: 1968 f100 power steering pulley
Post by basketcase0302 »
Which one?
SBF / FE / BBF?
Crankshaft / Water pump / or power steering pump pulley?
I have a few for sale here:
http://www.fordification.com/forum/view ... 11&t=82828
Schmidty
Post by Schmidty »
Thanks for the replies. I'm looking for a power steering pump pulley. 4 1/2" diameter 11/16 shaft. Thanks for taking a look! Let me know if you have one lying around.
basketcase0302
The one that is on the pump itself is pressed on.
Is that the one you need, or do you need the one that goes onto the water pump-that the power steering pump belt rides on? :hmm:
Schmidty
Post by Schmidty »
basketcase0302 wrote:The one that is on the pump itself is pressed on.
The one I need is the pulley that is pressed on the power steering pump shaft. Still haven't located one. Do you have one you would be willing to sell?
Thanks!
basketcase0302
That would be the only one I do not have.
Sorry I couldn't help you.
Try Obsolete Ford Parts in N.C.
or Green Sales:
http://www.greensalescompany.com/
Mach428
Post by Mach428 »
I have two perfect PS pump pulleys that have been bead blasted and sprayed satin black. One has 11/16" shaft and one 13/16". Both; however, are 5 1/8" diameter. Also, the one on my 69 F-250 is 5 1/8". Why do you think it should be 4 1/2"?
