1guydude wrote:Hi
Im from wa state and just purchased a 1967 for f100 bumptruck. Im excited. Lots to do to this beast. Anyone point me in the right direction as far as buying parts?! Ive been looking at Rock auto.
Going to a 4x4 swap early this next month. So hopefully ill have some $ and find something I need.
Urgh this truck needs so much work! Starting with the brakes I guess.
Maybe ill post some pix of the beast up here one day. Both before and after its done.
Thanks
-devin
67? You'd better read this:
The hood is basically the
same 1967/72 F100/750. The original 1967 hood (
C7TZ-16612-A) had slightly different cross bracing, and that's it.
Ford replaced
C7TZ-16138-A with the 1968 hood
C8TZ-16138-A. Then in 1970, replaced
C8TZ-16612-A with
D0TZ-16612-A = thus: 1967/72 F100/750. If you're a purist, you'd want to retain the original 1967 hood.
1967: You push the inside handles forward to lock the doors from the inside. 1968/72's have door lock knobs.
1967
only: Door shells, window regulators, door lock remote controls, door latches and link rods, inside window and door handles, vent frames & handles, armrests.
Firewall, dash panel, radio & heater, instrument cluster back, brake & clutch pedals, bracket they suspend from. Master cylinders, P/B boosters, proportioning valves, low brake fluid warning lamp switch.
Hood side emblems, painted steel and anodized aluminum grilles. Ignition switch:
C5AZ-11572-B same as: 1965/67 Galaxie/LTD/Thunderbird / 1966/67 Fairlane/Falcon / 1967 Mustang/Cougar.
Same 1967/
72 door parts: R/L upper/lower hinges, outside door handles, door lock cylinders, door and glass weatherstriping, window & vent glass, division bars.
C3UZ-18495-A .. Heater Water Valve-Splices into inlet to heater core heater hose: 1965/72 F100/1100, 1963/67 E100.
1967, 1968
before serial number C56,001: The upper side mouldings are
1 1/4" wide // 1968
from serial number C56,001, 1969, 1970/72 Sport Custom: The upper side mouldings are
1 1/2" wide.
There are
two different inside mirrors. 1967
before serial number A70,001: C5ZZ-17700-C .. Chrome (same as 1965/66 Mustang).
1967
from serial number A70,001, 1968/69: C7OZ-17700-C .. Day/Night-Black vinyl, paint to match (same 1967 Fairlane/Falcon).
Parts Vendors & Resources
TABCO Inc.- US Made!Replacement Sheetmetal & Parts
Dennis Carpenter Ford Restoration Parts
National Parts Depot:Ford Truck Parts & Accessories | 1948-1979
MAC's Antique Auto Parts
Blue Oval Truck Parts
Jeff's Bronco Graveyard
LMC Truck - Ford Truck Parts and Truck Accessories
The Early Ford Store-San Dimas,CA
Truck & Car Shop (Orange, CA): 48-86 Ford Trucks, 66-86 Ford Bronco
C&G Early Ford Parts: 32-79 Ford Trucks (Escondido,CA)
Sacramento Vintage Ford
Flashback F-100s: 48-2008 Ford Truck Parts
Vintage Pickup Truck Parts & Restoration Resources Directory
Green Sales Company - Vintage NOS & OEM Parts
Summit Racing
Jeg's
Speedway Motors, Street Rod & High Performance Parts
RockAuto Auto & Truck Parts
Barry Rabotnick's Survival Motorsports - Ford FE Engine Specialists
Eaton Detroit Springs - Stock & Custom Coils and Leaf Packs
Carolina Machine Engines-Rebuilt Long & Short Blocks
Domestic Carburetors at Carburetors & More,La Porte, TX
Daytona Carburetor Parts Co - Restored, Rebuilt, & Parts Source, New Smyrna Beach, FL
Carburetors Unlimited - New, Rebuilt, and Carburetor Parts, Auburn, WA
Centech Wiring Harnesses - Early Broncos & 60-80 Ford Trucks
Shock Warehouse
Inline Tube -The brake plumbing experts
Benchworks Steering
Red-Head Steering Gears, Seattle WA
Borgeson Universal Steering Components
Moog Suspension & Steering Components
AKH Vintage Truck Wheels
Truck Pro / Bay Shore Truck Services - Drivelines, T-cases, Axles, & More
Dana-Spicer Axle Applications & Service Manuals
70 F100 LB 2WD, 360FE, E-Street EFI, TKO-500, 76K original miles.. follow my rebuild:
The Lo-Buck Bumpside
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
