Hey guys,
I was wondering if someone could help me track down a retainer pin for the shift lever. My three on the three included a very rickety Allen key placed in the hole, so everything is a bit loose.
If there's a substitute or stock piece that would be great.
Thanks!
E
Shift Pin
- eggman918
Re: Shift Pin
If its a fractional size i would try a roll pin Ace should have them and it'll cast less that a dollar to see if it will do the trick
