Pinion seal
massillon preacher
Pinion seal
Post by massillon preacher »
Pinion seal was leaking out the sides, changed the pinion seal now its leaking out the flange nut area, is the flange nut not down far enough? I have rear end out of truck and after I changed pinion seal I put cardboard under rear end with the flange part hanging down towards card board, no leak at all after 24 hours but it's been about 72 or more when I look today and I can see it coming from the nut area?
eggman918
Re: Pinion seal
Post by eggman918 »
Did you use silicone under the washer?
massillon preacher
Re: Pinion seal
No and not sure there was a washer there
eggman918
Re: Pinion seal
Post by eggman918 »
Remove the nut and washer clean with brake kleen and reassemble with silicone and blue LocTite :2cents:
sargentrs
Re: Pinion seal
Post by sargentrs »
massillon preacher wrote:No and not sure there was a washer there
Should have been? http://www.fordification.com/tech/image ... ential.jpg
