Pinion seal
Pinion seal
Pinion seal was leaking out the sides, changed the pinion seal now its leaking out the flange nut area, is the flange nut not down far enough? I have rear end out of truck and after I changed pinion seal I put cardboard under rear end with the flange part hanging down towards card board, no leak at all after 24 hours but it's been about 72 or more when I look today and I can see it coming from the nut area?
- eggman918
Re: Pinion seal
Did you use silicone under the washer?
Re: Pinion seal
No and not sure there was a washer there
- eggman918
Re: Pinion seal
Remove the nut and washer clean with brake kleen and reassemble with silicone and blue LocTite
Re: Pinion seal
Should have been? http://www.fordification.com/tech/image ... ential.jpgmassillon preacher wrote:No and not sure there was a washer there
