Clutch quick connect
anotherfordguy
Post by anotherfordguy »
Hey all, trying to get my bump finished and hit a road block. I swapped in 351w and ended up using a 93 M5R2. I had to custom build my long tubes and they pass right in front of the coupler to the slave cylinder. I need the hose to turn 90* up into a custom flex hose to the master. Where can I find a male quick connect that threads onto an aftermarket hose? Or what is the technical name of the coupler that I could look it up? Or any other ideas from someone that's battled this. Thanks a bunch.
71PA_Highboy
Re: Clutch quick connect
Post by 71PA_Highboy »
It has been a while, but IIRC you can pull the hard line out of the slave cylinder and take it to a tubing shop and get a custom tube made. It is held in with a roll pin.
You have to remove the slave from the trans to do this.
Good Luck!
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
