Cab looks really good. trade ya Awesome your making headway!!cdnwillyg wrote:So what is the plan on the cab? Looks pretty good from here!
- Manny
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
- hfdco4
I have a small spot on the floor to replace and have sourced a section from another truck. There is a dent just behind the passenger door I have to fix and I would like to seal up the gas filler hole in the Drivers side.cdnwillyg wrote:So what is the plan on the cab? Looks pretty good from here!
Paul
FE390PC
1970 F250 4x4
2016 F150 4x4 2.7 ECO
Gone 1988, 1989 & 1991 Broncs
FE390PC
1970 F250 4x4
- hfdco4
Once I get the floor sealed up I want to clean the bottom and paint it with POR15 that I have. The cab came from CA and someone left a rag on the floor which got wet and caused the root. The cab mounts are actually good.
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- cdnwillyg
Not too much at all Paul, at least compared to Manny's project! I used por 15 on a couple vehicles and I think its awesome stuff for rusted areas as long as they are cleaned. Good luck! keep us posted!
Stony Plain, Alberta, Canada
:drive:Willy
:drive:Willy
- hfdco4
Oh I will post pics as I move along.
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- Manny
Really............ I don't like you No happy you have a good one to deal with!!!hfdco4 wrote: The cab came from CA and someone left a rag on the floor which got wet and caused the root. The cab mounts are actually good.
Here is one of the brake spiders i got cleaned up. Let me know i will clean the other one up if you need them.
- hfdco4
Thanks Manny and yes let me know what I need to send you buddy!
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- hfdco4
Cab pictures.
Drivers Side.
Drivers Side.
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- hfdco4
Passenger Side.
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- hfdco4
Passenger Side continued.
So that is what I have to work with. This cab has journeyed far and wide. Was a Cali Truck, then I saw it in the town I lived in Massachusetts south of Boston. I finally ended up traveling to North of Boston to actually buy this thing. I removed the Cab and Bed and scrapped the frame. Then trucked it to Maryland where I bought another two wheel drive for parts that has a better bed.
I am extremely lucky to have stumbled onto a cab in very good shape.
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- cdnwillyg
Wow that looks great, nice start. Sure looks solid and straight especially for after 50 years!!
:drive:Willy
:drive:Willy
- hfdco4
The funny thing is this truck sat for a couple of years 10 miles from my house in Mass. Tried on several occasions to buy it, finally bought it when it was almost 60 miles from my house in Mass.
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- popeyes71
funny how that works! To bad you couldn't have purchased it when it was closer. Oh well, at least you ended up with it and it looks good and solid!
-Popeye-
1971 F-250 4x4 Highboy
- hfdco4
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- Bullitt74
Steve F.
Red Deer, Alberta, Canada
'72 Ranger XLT, 4x2, 390-2V, C6, Wind blue & Wimbledon White (‘Smokey’)
2016 F150 Lariat FX4 Supercrew, Ruby Red
Follow my build thread for 'Smokey': http://fordification.com/forum/viewtopi ... 22&t=85070
