hfdco4
Post by hfdco4 »
Question for all of you. How did you flip your cab onto it's back? I was thinking of using blocking in this area, see pic.
Then lifting the front with an Engine Crane or the Gantry Crane?
Paul
:fr: FE390PC
1970 F250 4x4
2016 F150 4x4 2.7 ECO
Gone 1988, 1989 & 1991 Broncs
cdnwillyg
Post by cdnwillyg »
Paul, when I took my '55 cab off it only took two of us by hand and we flipped it on it's back, so I would think your cab should go that easy also. Maybe have three guys if you can! :2cents: I should mention that we didn't have any glass in it or doors on.
Stony Plain, Alberta, Canada
:drive:Willy
hfdco4
Post by hfdco4 »
Thanks Willy, most of the time it's just the wife and I doing the work.
Paul
:fr: FE390PC
1970 F250 4x4
hfdco4
Post by hfdco4 »
So was looking for my spring pad again and ran across more parts to get rid of. The outers from a Dana 44HD Closed Knuckle axle.
Paul
:fr: FE390PC
1970 F250 4x4
Manny
Post by Manny »
hfdco4 wrote:So was looking for my spring pad again and ran across more parts to get rid of. The outers from a Dana 44HD Closed Knuckle axle.
Hey wanna trade some parts??? I always love the big hub stuff, and spares are great!
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
hfdco4
Post by hfdco4 »
What do you need or want?
Paul
:fr: FE390PC
1970 F250 4x4
hfdco4
Post by hfdco4 »
Got back out to the garage today. Working on the floor patch first. Got the patch laid on top of the floor and marked for cutting. Have to put a few rivets in then I can cut.
Paul
:fr: FE390PC
1970 F250 4x4
Lone Ranger
Post by Lone Ranger »
Wow what a nice cab! You'll have that ready to go in no time!
Kyle
Manny
Post by Manny »
Hey Paul glad your getting some of the patches done, and the wife didn't kill you for being gone valentines. The hubs just let me know what you need for all of it we will swap stuff around. You find that spring pad?
hfdco4
Post by hfdco4 »
I sold one set of hubs and backing plates to a guy on the dent forum. I have the complete axle I can take stuff off for you, that is in much better shape. I did get home on "V" day so I am still breathing. I did have a bad week so far health wise though.
Paul
:fr: FE390PC
1970 F250 4x4
hdman90
Post by hdman90 »
Hfdco4!
Wow! What attention to detail. The Highboy I am rebuilding also has the larger hubs, cool to know I'm not the only one dealing with them!
I am very interested to see how your rear leaf hanger flip turns out. I also have a 2wd frame at my disposal, so it may be worth doing the same!
Until we see it complete, keep up the great work!
1969 F-100 LWB 2wd 240 3spd manual
1969 F-250 LWB 4wd 360 4spd manual
1976 F-250 Supercab LWB 2wd 390 4spd manual
hfdco4
Post by hfdco4 »
Here is how it sits today.
Paul
:fr: FE390PC
1970 F250 4x4
hfdco4
Post by hfdco4 »
The biggest change was keep the rear axle centered in the wheel well of the bed. I had marked the frame/wheel center line and reworked the rear drive shaft so the slip joint works within its travel.
Paul
:fr: FE390PC
1970 F250 4x4
Manny
Post by Manny »
Looks good and that's interesting on the keeping the axle centered didn't think about that fully. Also i d have two extra spring pads here. Need to keep a spare for good measure? :lol:
Bullitt74
Post by Bullitt74 »
:thup: Looks like progress!
