302 with 351 firing order???? why?
Engine, ignition, fuel, cooling, exhaust
BayStYAt
Re: 302 with 351 firing order???? why?
Post by BayStYAt »
Twisted_Steel wrote:I ran shorties on my 85 and 86 Mustang GT's and never had a problem with leaks. Not saying they won't...just mine didn't.
What year 302 is in your truck? My Ranger has the 302 HO from a 1985 GT. It has the 351 firing order as did all the H.O. 302's from that era. Funny thing is, it was "high output" for that time. The 302 in my 2014 Mustang is as big as the 429 in my 69 bump side and has double the HP of the stock 85 engine.
The year is still a mystery. It originally had a 360. It know now has a 302 with 351 heads. It has a Mercury tag on the block. I think this means ford put an engine in at some point. It is running the 351 firing order.
I am still trying to figure out all the changes since 1971.
ButtaBean
Post by ButtaBean »
Are you 100% sure its a 302 block? I've seen a good number of them misidentified, even by the person that installed them.
BayStYAt
Post by BayStYAt »
ButtaBean wrote:Are you 100% sure its a 302 block? I've seen a good number of them misidentified, even by the person that installed them.
Yes sir, it has a 302 intake.
Ranchero50
Post by Ranchero50 »
Post some pictures of the weight on the balancer and flywheel if you have them. Might even be a 5.0, not a 302...
BayStYAt
Post by BayStYAt »
Ranchero50 wrote:Post some pictures of the weight on the balancer and flywheel if you have them. Might even be a 5.0, not a 302...
ok, I always thought a 5.0 was a 302?
BobbyFord
Post by BobbyFord »
Prolly a 50 oz. balance motor with that firing order.
BayStYAt
Post by BayStYAt »
BobbyFord wrote:Prolly a 50 oz. balance motor with that firing order.
bobby, I got no clue what your saying! hahaha
Ranchero50
Small block fords have an imbalance built into the crank that is compensated for by a weight on the flex plate and harmonic balancer. Since you don't know what flavor engine you have it'll help to know what the imbalance is. Probably wouldn't make much difference long term but might help you get the correct parts.
BayStYAt
Post by BayStYAt »
Ranchero50 wrote:Small block fords have an imbalance built into the crank that is compensated for by a weight on the flex plate and harmonic balancer. Since you don't know what flavor engine you have it'll help to know what the imbalance is. Probably wouldn't make much difference long term but might help you get the correct parts.
ahhhhhh, awesome.
Ranchero50
3 bolt pulley is pre 1970.
Is that timing over iron and not aluminum? Never seen an iron one.
BayStYAt
Post by BayStYAt »
Ranchero50 wrote:3 bolt pulley is pre 1970.
yes iron
BayStYAt
Post by BayStYAt »
yes iron
so, pre 70, 351 firing order and iron timing cover. YIKES! rabbit hole
The Bandit
Post by The Bandit »
yes iron
No not a rabbit hole at all. Those iron covers were used on 289 302 and 351W and some marine engines in boats. so they were kindof common at one point. Just really heavy though.
"Don't believe everything you see and read on the internet." Abe Lincoln
1972 F100 custom SWB 302/C4 Auto PS No AC Wimbledon white and rusty..
Ranchero50
Never seen one in cars or trucks. Industrial duty sounds plausible. Really adds some questions to what you have and where it came from. What does the tag on the back of the engine say. Mercury as in Mercury Marine as in prior I/O or direct shaft engine?
It's a mystery I say... :?
BayStYAt
Post by BayStYAt »
Ranchero50 wrote:Never seen one in cars or trucks. Industrial duty sounds plausible. Really adds some questions to what you have and where it came from. What does the tag on the back of the engine say. Mercury as in Mercury Marine as in prior I/O or direct shaft engine?
HOLY crap, its a marine block. What the hell! where do I go from here?
