I'm having a problem with my E-Brake not staying engaged. It's like the teeth are not engaging when it clicks down and then pops back up.
Is there an adjustment
E-Brake Pedal Releasing
Re: E-Brake Pedal Releasing
No adjustment at the pedal that I know of. The spring on the handle is what keeps the cam locked into the gear on the pedal. If that's weak, I can see it no having enough pressure to keep it engaged.
The single most common reason your parking brake won't engage is a need to adjust the brake shoes. The cable must attach to both rear brakes for your parking brake to work -- if it attaches to just one side, the brake will engage but feel loose, and the car will roll on a hill.
