Summit C-6 Deep Pan on 2WD truck?
DuckRyder
Post by DuckRyder »
Anyone used this pan:
https://www.summitracing.com/parts/sme-1003r
On a 2WD FE/C6? Does it clear the crossmember?
Some of the reviews seem to indicate it won't and some that it won't on a 4wd... :?
basketcase0302
Re: Summit C-6 Deep Pan on 2WD truck?
Post by basketcase0302 »
It was an upgrade i always wanted to do to my C-6 302 Robert that i never got done. :(
BUMP!
RottenAppleRed
Post by RottenAppleRed »
Hope this isn’t too late. Here’s what I’ve found...I have a ‘72 bump LWB with a healthy 351C mated to a C6. I purchased a Hughes deep cast pan for my C6 and the radius arm cross member is in the way for a deep pan. My truck had a 302/3spd stock. I used the factory frame mounts for the engine mounts and standard small block motor mounts, as a Cleveland is a small block. I did have to move my trans crossmember back a few inches for the C6 as well as cut the front driveshaft and switch to a slip yoke.
The radius arm crossmember is in the way at the front of the pan, so a forward moved engine should only make it worse.
