started my tank swap
emeraldcoupe
Re: started my tank swap
Post by emeraldcoupe »
It's a 23 gallon tank, the mustang ones run from 16-22
emeraldcoupe
the second to last pic is deceiving, it looks like the tank is real low, but it's the tire on the truck next to it.
emeraldcoupe
SPECTRA PREMIUM SP378H is the fuel pump hanger i used, i just replaced the low pressure pump with one for a '90 5.0 mustang. this hanger also has the sending unit built in, and it's a 10-70 ohm that matches the factory fuel gauge, so the gauge should read correct and work fine.
