Posting more than three pictures?
Comments, suggestions or site/forum assistance
JWW
Post by JWW »
I’ve researched a little on here but can’t find how to post more than three pictures at a time. I’ve seen other posts with more than three pictures. How are you doing this? Are my file sizes too large? Thanks
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
MAK
Re: Posting more than three pictures?
Post by MAK »
I link to photos I’ve put on my own domain so have never tried using the gallery that was added here several year ago. Are you having the 3 photo limit when you try to add more than that to your personal gallery or when you try to link them within a post?
http://fordification.com/forum/viewtopic.php?t=84949
MAK
Post by MAK »
Actually I don”t even see a gallery option in my profile anymore…
JWW
Post by JWW »
MAK wrote: Fri Jun 02, 2023 2:18 pm I link to photos I’ve put on my own domain so have never tried using the gallery that was added here several year ago. Are you having the 3 photo limit when you try to add more than that to your personal gallery or when you try to link them within a post?
Thanks Mak. I was uploading the files from my computer. It limits to three per post. I'll see if I can link from one drive or another source.
I had just updated my project but had to post multiple replies to get all the pictures in. See link: https://www.fordification.com/forum/vie ... hp?t=23983
JWW
2004 F150 Crew Cab
MAK
Post by MAK »
That’s coming along great. Really looking good. I don’t feel so bad knowing there are others who have been working on their project for years…
The photo posting limit would definitely be frustrating. Not nearly as easy as some forums where you don’t have to first create that personal album, etc. I’ll deal with it though, can’t stand Facebook groups unless there is no other option. :D
JWW
Post by JWW »
MAK wrote: Fri Jun 02, 2023 3:16 pm That’s coming along great. Really looking good. I don’t feel so bad knowing there are others who have been working on their project for years…
Thanks Mak. I wish I had the body and paint skills like you have on your truck. I’ve told people mine wasn’t done in a 30 minute episode on MotorTrend. 😀
JWW
2004 F150 Crew Cab
Jbarnes79
Post by Jbarnes79 »
I use flickr to host my content then use a simple line code in my post for it to show up. If you use this method then after you upload a photo (to flickr for example) you can right click on the photo and select "inspect element". That will pull up a bunch of code but inside of it you can find the direct web address link to the image. A little weird at first but once you figure out what link it is then you find it pretty fast afterwards. Once you have that then put the following in your forum post to have it show up.
[img]your link[img]
https://www.bbcode.org/posting-images-with-bbcode.php
http://fordification.com/forum/viewtopic.php?t=67810
1969 F250 4x4
1969 F250 Crew cab (Sold)
1972 F250
1969 & 1970 Mustang
JWW
Post by JWW »
Jbarnes79 wrote: Sat Jun 03, 2023 5:28 am I use flickr to host my content then use a simple line code in my post for it to show up. If you use this method then after you upload a photo (to flickr for example) you can right click on the photo and select "inspect element". That will pull up a bunch of code but inside of it you can find the direct web address link to the image. A little weird at first but once you figure out what link it is then you find it pretty fast afterwards. Once you have that then put the following in your forum post to have it show up.
[img]your link[img]
Thank you. I used to use Photobucket several years ago but they started charging.
I’ll give Flickr a try.
JWW
2004 F150 Crew Cab
JWW
Post by JWW »
Test with onedrive.
*Edit, back to the drawing board.
JWW
2004 F150 Crew Cab
Jbarnes79
Post by Jbarnes79 »
I don't see an image. I made a typo with my code example if you didn't catch it already. Sorry about that.
[img]your link[/ img]
just delete that little space between the / and img
the first bracket without the / is correct and only needs to go one the end one.
1969 F250 4x4
1972 F250
1969 & 1970 Mustang
JWW
Post by JWW »
Jbarnes79 wrote: Wed Jun 07, 2023 12:29 pm I don't see an image. I made a typo with my code example if you didn't catch it already. Sorry about that.
Thanks, I'll try again.
JWW
2004 F150 Crew Cab
JWW
Post by JWW »
It worked this time.
JWW
2004 F150 Crew Cab
