Aftermarket A/C
460 crew
re: Aftermarket A/C
Post by 460 crew »
My condenser has 2 tubes connecting eachother on one side then every three on the other so sounds like the older style. I'll just see what I get with it charged properly when I have the cash then maybe if it's not satisfactory I'll try a condenser upgrade. Also I have a 10in pusher fan i was going to mount on the front of everything to chill things a little in stop and go traffic and idling. Try one thing at a time and see if I get any improvment. Prob be done by winter. :lol:
Joe Kriston
re: Aftermarket A/C
Post by Joe Kriston »
Hey,thanks for the comps Mercman....I just had the unit charged up today....Since it's an old add-on,there's several hoseclamp type connectors which are more prone to leak...Recharging it got me through last summer,but I needed about a pound and a half to get the proper reading...Fortunately,I have a buddy that does it for me for the freon cost...Anyway,it's blowing out nice and cool but still poor circulation(kinda like my own bloodflow :o )...I'll check the current,and anything else that may look amiss....
460 crew
Re: re: Aftermarket A/C
Post by 460 crew »
mercman1953 wrote:460 crew One thing I thought about is what kind of a condensor do you have? Is it a tube and fin type or a newer style. Look at it. Does it have a long tube running up and down or does it have tubing connecting each row. The long tube runnig down the side is the newer style and will work much better. It was designed for R-134a and works better for us. You have a tough job living in Nevada. kind of like us in Texas. Let me know
Ok I decided to take the route of just changing out my condenser for a parallel flow newer style. http://cgi.ebay.com/ebaymotors/ws/eBayI ... AMEWN%3AIT
Seems like a good deal and I'm going to add the 10in pusher fan to that and have a shop here in town look it over and charge it that is from what I heard pretty reputable. I'm also pondering the thought of adding vents like I saw in another post for a truck that was for sale. They had the vents mounted in the dash bezel on the sides. I figure one on each side of the bezel and one in the empty area next to the glove box door. I put the vent hose off one of my vents on one of these, http://store.summitracing.com/partdetai ... 20&FROM=MG
and it blew alot better than trying to put it through the square vents I have that came with my kit. I bought one just to see if I liked them... well got it for fathers day. and I think they'll look pretty nice and be functional. I snapped some pics just holding it up with my hand, so opinions on if I should take this route or not would be appreciated.
re: Aftermarket A/C
Man, those would fit really nicely into an F600 dash panel and look great too. Hmmm.... ;)
460 crew
re: Aftermarket A/C
Post by 460 crew »
Ok I got the one vent mounted today, thought I had it centered perfect but I never fail myself it was off a bit but still looks pretty decent and the airflow is alot better and gets to the back seat. So I'll be ordering another for sure and maybe finding a square one around the same style for the passenger side of the glove box door.
trukcrazy
re: Aftermarket A/C
Post by trukcrazy »
That looks like it should've been put there by Ford. I think you should use the same vent on the right side of the dash. Very good piece. :thup:
John, #424
1967 F250 crewcab x 2.
2008 Challenger SRT8
460 crew
re: Aftermarket A/C
Post by 460 crew »
Thanks, Yeah I need to get another one on the way for the right side of the bezel. It had to be shaved down on the back side so that it screwed together somewhat flat because the bezel is rounded. Dremel tools are the best. along with the 2.5in hole bit I picked up. :D
460 crew
re: Aftermarket A/C
Post by 460 crew »
Just an update to the A/C issue I added the parallel flow condenser yesterday and my uncle bought some new gauges and vacume pump so I had him do the whole thing and with the truck sitting there at idle it was pumping out cool air in the teens and low 20's. So the only issue left to tackle is putting 2 more of the round vents in to get the air flowing around the cab. I'll probably find a rear unit for the back someday out of a junked vehicle when I decide on what newer style seats I want to put in. :D I am thrilled that it's working well in the LV heat. :woohoo: Thanks for the insight on the condenser mercman1953.
flyboy2610
re: Aftermarket A/C
Post by flyboy2610 »
:clap: :clap:
dotcentral
Post by dotcentral »
Flyboy, this is an interesting link, but no info on where to go get their conversion. Is this a link for dealers & do it yourselfers (probably not a word :oops: )?
alvinator
re: Aftermarket A/C
Post by alvinator »
her mercman,
your just around the corner from, i am in Rowlett. I have a 69 F100 that the a/c is aftermarket but doesn't work. I may be calling on your when i get to working on it.
Big D's 69
Post by Big D's 69 »
I like those vents you installed 460Crew. Those will look good when you get them all installed and it will be a lot cooler afterwards. making use of wasted space in the dash.
Fake Name
Post by Fake Name »
Well, this heat wave out here in California is expensive. I just ordered a Hypercool1 complete heat and air unit from Rainbow Products, a link I first saw somewhere on this forum. I suspect that by the time it arrives and I clear a weekend to iinstall it, it will be winter :)
I'll let you know how it goes...
fn
lazyj70
re: Aftermarket A/C
Post by lazyj70 »
I changed my factory a/c over to 134 and it cools fine. It won't put frost on the windsheild or anything, but I dove it today and it was 107 degrees and I was comfortable.
2008 F-350 Lariat Crew Cab 4X4 Western Hauler
1970 F-100 Ranger XLT.
flyboy2610
You'll have to find someone certified to do AC work who can order it for you.
They will have to evacuate the system and refill it with the Freezone. I don't think there is any hardware conversion required. At least that's what I gathered from the website.
