Firewall cover - What to do next?
- 460 crew
re: Firewall cover - What to do next?
I had purchased the firewall cover from Dennis carpenter, there was a little trimming here and there where some of the extra things go through. Most have the ABS precut but it is still intacted along with the insulation behind it. Here are a couple pics of when I put it in there. If anyone needs pics of a particular area of it let me know.
- Sharkdance
460 crew,
That looks excellent! Thanks for the pix.
- trukcrazy
That cover looks pretty good. I may have to try one of those in mine if I destroy the original when it comes time to remove it. Good pictures.
John, #424
1967 F250 crewcab x 2.
2008 Challenger SRT8
![Image](http://www.fordification.com/images/forum/Signature-1.jpg)
- 460 crew
Thanks guys. For the most part my only complaint is that it is a little on the stiff side and I need to find some other plastic plug keeper things to really suck it up to the firewall. It's stiff enough that it needs a little persuasion to sit just right, other than that it's a quality product but not original, I've gotten used to it, and it's easy to clean.
- trukcrazy
Did you use the plastic plug fasteners or the metal ones? It's hard to tell from the photos that it doesn't quite fit perfectly.
John, #424
- 460 crew
Plastic, thats why they don't hold it very well. It fits good it just isn't totaly snug up against the wall at the bottom. My A/C unit is helping it right now.
