302 with 351 firing order???? why?
DuckRyder
Re: 302 with 351 firing order???? why?
Post by DuckRyder »
BayStYAt wrote:
BayStYAt wrote:I think I am gonna go with this kit instead. I listened to some 302 on youtube and its a great street kit
http://www.compperformancegroupstores.c ... gory_Code=
You should do dome reading on camshaft theory and you’ll also need to rerun your dynamic compression numbers with that cam.
I personally think a single pattern cam is horrible choice for a SBF...
BayStYAt
Post by BayStYAt »
thank you Duck,
are my head bolts reusable? Are they TTY?
DuckRyder
Post by DuckRyder »
BayStYAt wrote:
DuckRyder wrote:
BayStYAt wrote:
You should do some reading on camshaft theory and you’ll also need to rerun your dynamic compression numbers with that cam.
thank you Duck,
I don’t know about the head bolts.
Seriously do some checking on the cams and go read http://www.fordification.com/forum/view ... =3&t=87861
Ford heads are generally not very good on the exhaust side, so you’ll find a lot of people (me included) like to run more exhaust duration and lift. That 268H is a single pattern cam and a very old design at that. I would go with the Thumpr all day every day out of those 2.
BayStYAt
Post by BayStYAt »
DuckRyder wrote:
thank you Duck,
Ok, I will go with the Thumper. Thanks for that info
BayStYAt
Post by BayStYAt »
Has anyone done a DIY project on the radiator mounting kits? $40 plus shipping for a few pieces of rubber and bolts seems high.
DuckRyder
Post by DuckRyder »
BayStYAt wrote:Has anyone done a DIY project on the radiator mounting kits? $40 plus shipping for a few pieces of rubber and bolts seems high.
What radiator mounting kit?
BayStYAt
Post by BayStYAt »
https://www.autokrafters.com/p-9963-rad ... 8125s.aspx
DuckRyder
Post by DuckRyder »
That is a Radiator SUPPORT mounting kit. It is basically the front set of body mounts.
BayStYAt
Post by BayStYAt »
I need to come up with a DIY for this. $60 for this is a bit much.
Block and crank are at the machine shop. As soon as I get word from them I am ordering the Federal Mogul kit. I found a bent exhaust valve and one exhaust valve was sticking open. I am sure that was and issue with loss of power. Inside the valve guide had a bunch of sticky oil in it. Cleaned it so its smooth now.
BayStYAt
Post by BayStYAt »
I want to replace pushrods, I have a 302 with 351 heads. DO I buy rods for a 302 or a 351?
ButtaBean
Post by ButtaBean »
BayStYAt wrote:I want to replace pushrods, I have a 302 with 351 heads. DO I buy rods for a 302 or a 351?
If you're using a 302 block, you'll need 302 pushrods, but if any mill work has been done to the heads, you'll need to measure them to get the correct size or your pistons might rudely introduce themselves to your valves.
BayStYAt
Post by BayStYAt »
awesome thank you
what about length when changing the cam?
Ranchero50
Post by Ranchero50 »
As long as the base circle is the same and the lift is within the tolerance of those old cast rockers stock length will work.
BayStYAt
Post by BayStYAt »
Ranchero50 wrote:As long as the base circle is the same and the lift is within the tolerance of those old cast rockers stock length will work.
thanks Ranch.
BayStYAt
Post by BayStYAt »
SO upon finding out my head bolts are 7/16" BUT I have 351 heads that use 1/2". I noticed that in order to run 351 heads there are step washers that are required. I did not have step washers on my set up. I don't know if this was done from the factory or not. what should I do now?
