my green 68
Re: my green 68
I was wondering what kind of shorty headers you used? How was the fit? I have a 302 I'm trying to decide which shorty headers to use.
My build thread...http://www.fordification.com/forum/view ... 22&t=67317
- tybob81
Re: my green 68
Fox body style fit fine.
- tybob81
Re: my green 68
![Image](http://i235.photobucket.com/albums/ee2/teabag78/68%20f100/2012-10-26_16-01-12_168.jpg)
Test fitting the intakes. Still have to bead blast my upper and lower.
- 72bumbee
Re: my green 68
Wonderful truck!
Thanks for sharing!
Thanks for sharing!
“To succeed in life, you need two things: ignorance and confidence.”
Mark Twain
1972 F-250 Camper Special. 360 A/T P/B AND a DANA 60 Rearend!
Former owner of dads 1967 F-100. It has gone home to the big road in the sky...
Mark Twain
- tybob81
Re: my green 68
Starting to get it put back together. Gt40 3 bar head swap done along with bolting down my 1.72 roller rockers and edelbrock performer 5.0 lower, 24# injectors and explorer fuel rail. The upper has a 70mm tb.
![Image](http://i235.photobucket.com/albums/ee2/teabag78/2012-11-15_09-53-21_962.jpg)
I modified a stock fox body 5.0 throttle cable bracket to work with my lokar tv cable and bought a universal lokar throttle cable to match the tv cable. Im either going to use a lokar pedal or a modified stock pedal I made.
Have to finish hiding and routing my wires for the MSD digital 6al box and efi harness.
- sargentrs
Re: my green 68
SWEEEEEEET!
- tylerb43
Re: my green 68
Wow, that's a pretty motor buddy! Love the blue lower, what color are you doing on the upper?
- tybob81
Re: my green 68
The upper is a bright silver like it was new from Edlebrock.
- tybob81
Re: my green 68
![Image](http://i235.photobucket.com/albums/ee2/teabag78/68%20f100/2012-11-20_09-03-20_372.jpg)
![Image](http://i235.photobucket.com/albums/ee2/teabag78/68%20f100/2012-11-20_09-03-01_262.jpg)
![Image](http://i235.photobucket.com/albums/ee2/teabag78/68%20f100/2012-11-20_09-02-33_464.jpg)
Still waiting on my plenum spacer to come in. The valve covers I'm running are a little taller than stock and my throttle cable bracket touches the passenger cover. I should have the fast efi covered in powerbraid tomorrow. Still need a adjustable fuel pressure regulator since my rails use a 94 and up style mustang (2 bolt) regulator and all I have is a fix style (3 bolt)
- tybob81
Re: my green 68
![Image](http://i235.photobucket.com/albums/ee2/teabag78/68%20f100/2012-11-29_08-46-17_828.jpg)
![Image](http://i235.photobucket.com/albums/ee2/teabag78/68%20f100/2012-11-29_08-46-54_969.jpg)
![Image](http://i235.photobucket.com/albums/ee2/teabag78/68%20f100/2012-11-29_08-46-05_687.jpg)
Getting there. Hope to have it up and running again before Christmas.
Re: my green 68
I got a 2 bolt adjustable reg. from Orielly auto for about $40. Seems like it was an 5.0 Explorer applicationtybob81 wrote:[i. Still need a adjustable fuel pressure regulator since my rails use a 94 and up style mustang (2 bolt) regulator and all I have is a fix style (3 bolt)
'68 SWB custom cab Bump. Under construction.
'66 bronco
'68 bronco
'66 bronco
'68 bronco
- tybob81
Re: my green 68
Yes the factory one on it was adjustable, but only 30-40 psi. Fast efi system neefs 43 psi.
Re: my green 68
tybob81 wrote:Yes the factory one on it was adjustable, but only 30-40 psi. Fast efi system neefs 43 psi.
Sorry. I missed that detail
Just curious. Why are you running FAST over the factory setup? I put the factory MAF setup on the 351w in my 66 bronco, and am very happy with it. Sorry for the derail. Just curious
'66 bronco
'68 bronco
'66 bronco
'68 bronco
- tybob81
Re: my green 68
The fast efi is tunable. I have ran factory harness and computers before in efi swaps and they are fine but not as crisp and they don't handle mods as well as the aftermarket does. I keep wanting to put my 393w back in or a 501 lima I have in my shop.
