Looks great!Speedpin wrote:Old blue got a new pair of shoes from Santa! 18x8 and 18 x10. 255 and 295's.
bumps with lowered altitude!! (lots of great custom bumps!!)
- JG F100
Re: bumps with lowered altitude!! (lots of great custom bumps!!)
72 F100 - SWB conversion w/05 crown vic IFS, 8.8 rear w/disc, 20s, 360FE w/overdrive
Project Page: http://www.fordification.com/forum/view ... 22&t=37897
- DanoF250
Hey moondog, does that picture show ride height or aired out height?
Thanx Dano
Thanx Dano
1970 F-250: No mods, no resto. Just gonna drive it!
- pincheweddo
- Craigerf100
I'm thinking of lowering the front a bit. Hmmm ![Hmmm :hmm:](./images/smilies/icon_hm.gif)
1968 F-100 Short Bed
1967 Fairlane 500 Convertable
1967 Fairlane GT/A 289ci SOLD
My Build:
My Build:
- pincheweddo
Doing the front just cost money. Doing the rear takes work.Craigerf100 wrote:I'm thinking of lowering the front a bit. Hmmm
- Craigerf100
I'm thinking just a spring kit. I only need 2" drop max. I found some on ebay.
My Build:
My Build:
- pincheweddo
I used the dream beams on mine for 3" on the front. I C notched the back for 6". I can still crawl under it and work on it. Shortening the springs on the front will cause you tire and wheel travel issues. The donor truck I purchased used springs and it ain't pretty.Craigerf100 wrote:I'm thinking just a spring kit. I only need 2" drop max. I found some on ebay.
![No No :nono:](./images/smilies/icon_nono.gif)
- Craigerf100
i wont be cutting them ill be buying lowered springs, made that way.pincheweddo wrote:I used the dream beams on mine for 3" on the front. I C notched the back for 6". I can still crawl under it and work on it. Shortening the springs on the front will cause you tire and wheel travel issues. The donor truck I purchased used springs and it ain't pretty.Craigerf100 wrote:I'm thinking just a spring kit. I only need 2" drop max. I found some on ebay.You would be better off leaving it stock height than cutting the springs.
or are you saying there isnt a difference they will both cause wheel travel?
My Build:
My Build:
- pincheweddo
Spring height is spring height. Cut or shorter the net result has the same effect on the geometry. Your suspension will loose wheel travel and the wheels will look as though you just made the jump over the bridge that was out in a Dukes of Hazard episode. Folks here will tell you to bend the beams back to level and it can be done, some say it is questionable. If you just buy the beams nothing is to question, the stock springs, stock shocks are used and the wheel travel is good. After driving mine I swear I wouldn't notice the ride difference with my new beams had I been blind folded. With the cost of tires these days, the beams are worth it. With the cost of gas, closer to the ground helps the mileage.Craigerf100 wrote:i wont be cutting them ill be buying lowered springs, made that way.pincheweddo wrote:I used the dream beams on mine for 3" on the front. I C notched the back for 6". I can still crawl under it and work on it. Shortening the springs on the front will cause you tire and wheel travel issues. The donor truck I purchased used springs and it ain't pretty.Craigerf100 wrote:I'm thinking just a spring kit. I only need 2" drop max. I found some on ebay.You would be better off leaving it stock height than cutting the springs.
Had it not been for a previous owner improperly installing a radius arm bolt, I would have had the beams installed, new king pins, drum brakes to disc brakes, new shocks, and on the ground in about 5 hours.
Summit Racing ships for FREE!!!
![Woohoo! :woohoo:](./images/smilies/icon_woohoo.gif)
Here is a link to the conversion:
http://1967f100.blogspot.com/2012_11_01_archive.html
That is the ride height. I don't have bags just dropped beams and 1 coil removed in front and an axel flip in the rear. It's my daily driverDanoF250 wrote:Hey moondog, does that picture show ride height or aired out height?
Thanx Dano
- toddspeed
question for those that did lowering shackles on the rear - do they require new rear hangers as well or will the stock hangers work?
Todd in Atlanta
1970 F100 Ranger born the same month/year as me - 360 C6 2WD, P/S, LWB
You! Yes You! Please put your location in your profile - it helps us help you when it comes to parts, pricing, and advice.
- BrotherMabe
DJM Suspension offered the shackles and hangers together, so that is how I got the 4" in the rear.toddspeed wrote:question for those that did lowering shackles on the rear - do they require new rear hangers as well or will the stock hangers work?
However, I have seen some companies offer the shackles and the hangers separate, although I don't see why?
Good Luck!
- toddspeed
Yeah that's where the confusion comes in. I see them sold together and separately.
Here's a bit of history on my lowering situation:
http://www.fordification.com/forum/view ... =5&t=75146
Todd in Atlanta
Any lwb bumps lowered with the crown vic suspension?
I saw this one at the DangerZone show here in visalia. If you own this truck, hit me up. Would love to talk about your lower control arms.
