STICKY: 3G Interchange Facts. Read if you're thinking 3G
rjewkes
Post by rjewkes »
what about the volt reg? do you scrap it and wire to the newer plug?
I never had any battery problem with 208 watt stereo and my 100.2 amp amplifier. And extra marker lamps everything was brite except the cluster.
fuelly.com
Clarko
Post by Clarko »
Yes, just disconnect the reg unless you use the product from PA where it is replaced.
Brian
1969 F-250 Ranger Camper Special 465FE/C6 (waiting on AOD)
1988 Bronco 351W/AOD
1994 Bronco 351W/E4OD
turbocharged400sbc
re: 3G Interchange Facts. If you're thinking 3G, read here.
Post by turbocharged400sbc »
I just wanted to say thanks...this is one of the reasons i love this site...
I spent 1hr today before work looking in every one of our alternator boxes at my work (Autozone hanover park IL) and i think the one i found that i thought would work was that alternator right there...i'll check the part # when i get back to work tomarrow but it sure looks like the bugger...i guess i shoulda checked here first :D :oops:
wait! more's law dictates: two alternators are better than one....hmmm i like this theme... :lol:
james
1994 Olds 442 (425 cid-4 wheel drive-2 V6's) http://www.cardomain.com/id/94twinengine442 13.81 @ 98.2 MPH 1.9s 60's
68 F250 Camper Special 390FE/NP435/3.73D60
soon: 79 F350 disk brakes w/ 3.55 D60, pneumatic, 1750w AC inverter, Vector 1600w lightbar, 200A 3g alt, all a mobile gearhead needs
Clarko
Post by Clarko »
Bump
Brian
turbocharged400sbc
Re: re: 3G Interchange Facts. If you're thinking 3G, read he
Clarko wrote:Bump
this should probably be stickied...my 1800watt power inverter loves the new alt over the stocker...
though i now have a useless ammeter :lol:
Clarko
Post by Clarko »
Bump
Brian
Manny
Post by Manny »
Note i tried today to hang one on my 67 camp spec with the low hung brackets and the alt hit the front crossmember since it was highboy which would fit that clarko.....
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
Clarko
Post by Clarko »
HiBoy's different frame. Use one from same year 3.8. Smaller hole spacing.
Brian
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
Here's a good link to read with more info if you're contemplating this alternator swap:
http://www.network54.com/Forum/74182/thread/1176499765/
Here's another SIMPLE 3G wiring diagram:
http://www.bcbroncos.com/3ginstall.pdf
cathynkeith
Post by cathynkeith »
I have scrapped the regulator and have a 1 wire set up, gm style. Leaves the compartment clean and its simple.
http://s115.photobucket.com/albums/n292 ... type=local
Life is good...... when nothing is wrong that money can't fix.
1969 f100 flareside
1962 ECONOLINE TRUCK (done)
1975 Nova (almost done)
jbrown414
Post by jbrown414 »
Anyone know which 3G would work for a inline 6?
mljjones67
Post by mljjones67 »
I have a 91 sable. Just wondering what I need off it?? Just the alt. or some of the wiring too??
Clarko
Post by Clarko »
Grab the plug off the back and like 2 feet or more of the green with red stripe wire. It'll sure make it simpler to wire.
Brian
mljjones67
thanks clarko that helps
Clarko
Post by Clarko »
As long as the thread helps people out, the time spent researching was worth it.
Brian
