power windows
marz68
Post by marz68 »
I need to remove this setup to get some better pictures for you guy's.to mount the motor you will have to cut the stock mounting location that the crank handle used to mount to to make room for the new mount for the electric motor.For the switch you will have to get a switch that reverses the power or you can also run a relay. I wish I had time to do a tech article on this for you guys but I have been so busy with other projects that barely have time to sleep. :o
ranger240
Post by ranger240 »
that's cool Marz, I'll be doing this pretty soon, hopefully, and I'll take pics, and hopefully do a writeup.
"Nahh, go ahead and cook, we'll trow it out. Wouldn't want you to get rusty."
marz68
Post by marz68 »
ranger240 wrote:that's cool Marz, I'll be doing this pretty soon, hopefully, and I'll take pics, and hopefully do a writeup.
Go for it that sounds cool!
GT-Racer
re: power windows
Post by GT-Racer »
What really sucks about this set up though is one major problem.
:cry:
:cry:
:cry:
:cry:
:cry:
:cry:
:cry:
:cry:
:cry:
:cry:
:cry:
I had two motors I had from a stang I parted out but I gave them away last month cause I thought I wouldnt need them.
'67 F100 2wd shortbed - Beginning restoration.
351w, 5-speed, 3:70 gears (someday)
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....:)
spartman
Post by spartman »
DOH!!!!!!!!
