What do you keep in your bed-side tool box?
Nothing in mine yet but in my old truck I kept a fuel pump. I also had a Craftsman 100 piece tool box and some shop rags and a flash light. I put my last truck together to carry a 12 foot slide in camper and I thought it came in handy. Never had anything go bad in it.
1968 F250 Camper Special 390
1964 Galaxie hardtop 352
1967 Cougar project
1993 F350 Crew cab 5.8
1988 Bronco 5.8 C6
1966 Mustang fast back project
New 1962 Falcon Gasser project
1967 Cougar project
1988 Bronco 5.8 C6
- 19674x4
ide love to have one, an in bed box takes up precious bed space and with the tank behind the seat, the only room i have is under the seat
My Photo Album
Re: What do you keep in your bed-side tool box?
not much of anything good, a old tire irion and a cheepy jack only.
because picking up my tools and junk off the road pisses me off bad. You load the thing up good and do a fast left turn and fwing out goes all the crap on the road.
also the stuff rattles and bangs around in there so bad it drives me totaly nuts and bonkers.
I like my tools behind my seat in the cab, along with all my other good junk.
WHAT ?
- aramil
Re: re: What do you keep in your bed-side tool box?
that is a great idea, but then you have to walk out to your truck to get a pop, itwould suck in winter here, the pop would freeze but fall would be good cause it would be constantly coldChaseman wrote:I put some padding in , so I keep as much soda (mainly various types of cola) as I can stuff in there. I'm gonna put my tool,chains,etc. in my aluminum box.
I don't have to jump up to get my soda with the bed-side box.
72, f-100 ranger xlt, 360-c6, 2wd 84k miles.
77, ford f-150 custom 4x4, 400m-c6 SOLD
"the existence of flamethrowers is proof that someone, somewhere, sid to himself, "i want to set those people over there on fire, but i dont feel like walking over there to do it"
- FLATBEDFORD
But, above freezing, the beer will be cold.aramil wrote:that is a great idea, but then you have to walk out to your truck to get a pop, itwould suck in winter here, the pop would freeze but fall would be good cause it would be constantly coldChaseman wrote:I put some padding in , so I keep as much soda (mainly various types of cola) as I can stuff in there. I'm gonna put my tool,chains,etc. in my aluminum box.
Steve
1970 F350 DRW Factory 9' Platform/Stake, 360, T18.
Passed on to new care taker July, 2013
My Photo Gallery
http://s115.photobucket.com/albums/n298/flatbedford/
My Photo Gallery
- aramil
and its with you where ever you go too, perfect for fishing and camping.FLATBEDFORD wrote:But, above freezing, the beer will be cold.aramil wrote:that is a great idea, but then you have to walk out to your truck to get a pop, itwould suck in winter here, the pop would freeze but fall would be good cause it would be constantly coldChaseman wrote:I put some padding in , so I keep as much soda (mainly various types of cola) as I can stuff in there. I'm gonna put my tool,chains,etc. in my aluminum box.
- ford4x4fun
I wish I had a picture over here but I don't, I put in mine a DC to AC converter mounted with some threaded rod. And than a couple extension chords. When we going camping I can run lights, or a radio, and it has come in handy when I go down to the bottom fiel to pull parts off of trucks. I used it once to run a sawsall to cut exaust from a Transmission I was trying to pull. My bed also set in a garage for 30 years unmolested, so I don't collect moisture in there yet. I haven't had any problems with it.
CNR Radio Instructor
US ARMY Retired
1971 Ford F100 4x4 (390)
2015 Ford F250 Crew Cab 6.7l
US ARMY Retired
I LOVE mine. I hammer welded a tool box to a wedge shape (lengthwise) so it would sit crosswise in the front. In it I have old tool sets-sockets, comb wrenches, screwdrivers, hammer, elec repair stuff etc in it. It's all quite organized. In the rest of the box I have a 4 way, hyd jack, tow rope, tire chains, jumper cables. Never had it leak or fly open. It has all the stuff you may need in a great out of the way spot. It's pretty secure too, because most people don't even notice it. I don't want something in the bed taking up room, this one takes no extra room. I like to haul motorcycles or anything else without something in the way. I think it's a terrific option!!!
70F100: 410 Merc with tri-power, close ratio toploader, 4.56 detroit locker 9"
68F100 4x4: 390, 4 spd/NP 205, Rancho 4" urethane susp, 35x12.50 All Terrain T/A's
55F100
01F150 Daily Driver: TP tunes, AF1 intake, elec fans, Magnaflow exh, underdrive pulleys, Centerlines
55F100
I look forward to having one. Towards the end of the month I'm going just south of Chattanooga into N GA to pick up my new 8 foot bed, and it happens to have this option, so keep writing in on this thread, gives me some good ideas about what to stick in there. Are these things plastic or steel on the inside? The one in an old 78 F150 we had had a heavy duty ABS plastic liner, just curious if these in the old bumps were stamped steel or plastic. Reckon I'll find out soon enough. As the the doors popping open, might consider replacing that old paddle latch with the newer T-handle type that doesn't have that problem, much more secure. Had one of those old paddle latches on an under-bed box on one of my old rollbacks, lost a lot of tools on the road before I replaced it.
'40 pickup, '51 F6, '54 F100, '56 F600, '59 F100, '60 F100,
'64 Unibody, '64 F100, '66 F100, '66 Bronco, '67 Fairlane (wife's) '68 F100,
'72 F250 '72 F100, '77 F100 4X4, '83 F150 4X4, !944 2N, 1951 8N, 1952 8N, 1953 Jubilee
1960 881 Select O Speed, 1961 801, yeah I'm eat up with it.
Non-Ford: '41 Plymouth, '55 Desoto, '67 Jaguar 420, '72 Mercedes 220
'84 Subaru GL turbo coupe. I need more garage, maybe an empty Wal-Mart.
I have a tool set, jumper cables, towrope, some rope, bottlejack and a bottle of power steering fluid in mine. And a star wrench. All kinds of things.
Troy
- tybob81
Those bed side tool boxes are usualy rotted out by now around here in the rust belt!
I think they are virtually identical. I used the latch assy off a 78 model because I didn't have a key for mine. As I recall, the liner is the same too.mikeconner1 wrote: Are these things plastic or steel on the inside? The one in an old 78 F150 we had had a heavy duty ABS plastic liner, just curious if these in the old bumps were stamped steel or plastic. Reckon I'll find out soon enough.
55F100
55F100
- GSequoia
My '71 is all metal. The latch is solid as well, no issues there. Those who have them popping open should take a look at their latch and adjust it as needed.mikeconner1 wrote:I look forward to having one. Towards the end of the month I'm going just south of Chattanooga into N GA to pick up my new 8 foot bed, and it happens to have this option, so keep writing in on this thread, gives me some good ideas about what to stick in there. Are these things plastic or steel on the inside? The one in an old 78 F150 we had had a heavy duty ABS plastic liner, just curious if these in the old bumps were stamped steel or plastic. Reckon I'll find out soon enough. As the the doors popping open, might consider replacing that old paddle latch with the newer T-handle type that doesn't have that problem, much more secure. Had one of those old paddle latches on an under-bed box on one of my old rollbacks, lost a lot of tools on the road before I replaced it.
My box has jumper cables, a tire iron, an incomplete tool set, an incomplete 12V compressor, and some other junk my grandfather put in there about twenty years ago.
www.advlifestyle.com
1971 Camper Special (390 / C6 / D60)
1970 F250 High Boy (NP435 / Dana 24 / No engine, rusted to hell and back body, project to combine with above.)
1966 Rustang (289 / C4 Project stalled for ages)
1989 Jeep Cherokee (4.0 / Auto / D30 / D44 / 35's)
1996 Jeep Cherokee (4.0 / Auto / D30 / D35)
- 1971ford
That would be the '69
The '71 is getting much more than that. I have a big list of all the spare parts that i will be mounting and attaching to the truck.
-Ryan
- GSequoia
Just fill the roll cage with spare oil and put a tap on the front bumper.1971ford wrote:That would be the '69![]()
