one more step to the safest bump around...defroster idea!
- 1971ford
it was here. i read about it but im going with the vacuum idea.
my dad and i went vacuum parts shopping, and the vacuum store was closed, and wallyworld didnt have what i was looking for.
but the good news is, we drove around and found 3 bump one guy had two bumps, which i carded. also saw a really nice 69 ranger that looks exactly like mugwumps
-Ryan
- two-bit
re: one more step to the safest bump around...defroster idea
If you really want an easy to convert defroster duct for that opening. Check on the sizes and dimensions for the First Generation F-series trucks defroster ducts.
I remember that they are elongated and thin. They also have a tube connection on the bottom that would make it easier to hook up your vacuum cleaner hose.
Just something to think about.
Two-bit
Two-bit
Lowes and Home Depot have a whole wall full of hoses. I think it's a great ideal beefing up the defroster. They suck like they are and I have great heat in my bump.
I want to go a step farther and add a vent to blow on the side windows. They need it bad also.
On your other idea, air-horns, I want some train horns on mine.
There is a video of a guy tooling around town with a set of train air horns blowing them at un suspecting people. It was funny but in Charlotte it would get you shot. FAST.
There's a website selling them but they start at around $800 and go up past $3000. I don't want any that bad.
I'll have to settle with the electric ol truck horns I have and put them back on
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- 1971ford
your right! lowes has lots...
like this 14 in. attachment
http://www.lowes.com/lowes/lkn?action=p ... lpage=none
ill go to lowes and check that one out.
i might have to make my own though, since clearence isnt looking so good. but its really hard to tell, since there is nothing in the 69 to see if it will clear stuff, and you cant see the dash in the 71 because all the wiring and the cluster.
ill think of something...
-Ryan
- 1971ford
so i have found that clearence isnt an issue on either side. i should be able to get a vent in there and easily route the vaccuum hose through to the heater.
also the truck is going down to the welding shop either tomorrow or the day after, so i need to get a good plan of the hole size and stuff.
but i was thinking, how much would it even be better to do this idea, when instead i fab a nice mount to mount a CPU (computer) fan to the bottom of the vent, and use vacuum hose
wouldnt that be just as good? because i cant find a way to have the heat spread out, and not just blown straight out the 1 ft. wide vent out the middle.
-Ryan
