Let's see What the guy sent me the Box says E9TF-17C476-AA Sold me a 76 Bronco setup he said, looks like an 89 The switch says E7TB. I won't complain eBay for 12 bucks.mk wrote:Sorry, been a long day. I read it as being the same as dragon's switch
Now... dragon, do you have any numbers on your switch or timer box...
mike
Delay wiper switch question
- Dragon
Re: Delay wiper switch question
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
71 Service manuals Volumes 1,2,3 and 4 So ask away.
My Gallery
Spark test
My Gallery
Spark test
- mk
Tom, I've noticed that with an '86 timer in my '68, the wipers have a fairly rapid sweep in the delay mode. Do you think using the earlier pre-'80 box would make a difference? This is one of those things I've been meaning to try for quite a while but never think of when I'm working on the dang truck. My thinking is they may have changed the specs for the box because of the extra two inches in length of the blades from '80 up.
mike
mike
~Will Rogers
Mercury truck ID thread:
Ford truck model history:
Using dentside fender liners:
Matchbox diecast bumps:
~Will Rogers
- Dragon
It does not have variable sweep but only one intermittent sweep speed? If so the box is bad.
Old Fords Rule
My Gallery
Spark test
My Gallery
Spark test
- mk
The variable delay between sweeps works fine but the sweep seems almost too fast. Maybe it's just me...
mike
mike
~Will Rogers
~Will Rogers
- Dragon
The timing is from 15 seconds between sweeps to .5 Seconds between sweeps at the low speed wiper speed.
Old Fords Rule
My Gallery
Spark test
My Gallery
Spark test
- two-bit
Speaking of numbers:
I checked the relay and switch that i have.
Relay says D3TBAA, cannot read the switch.
Both Motorcraft components.
Did Ford have delay wipers as a special order before the '78 trucks? Otherwise how did it end up with a 1973 Truck part number designation?
Two-bit
Two-bit
- Dragon
Our 76 F350 wrecker had them when I worked for Hunt Ford. The relay could have been out of a car.???? D3TB so it is a 73 truck part.
Oh Wow http://www.autozone.com/R,622302/vehicl ... Detail.htm
Available for 1973 F100 replacement parts.
Old Fords Rule
My Gallery
Spark test
My Gallery
Spark test
- Hawkrod
Yes, as Dragon has already confirmed, intermittent wipers were available begining in 1973. It was an option just like some of the other rare stuff like CB radios, heated rear windows etc... They are out there but just not really as common as they were in the later 70's. I just scored a complete fog light setup from a 79, those are really rare in our area, I have only seen a handfull of them including when I was at the dealership when they were new! There are a lot of rare items that you would never know about unless you looked through all the sales books, order sheets, dealer letters and parts books. I actually did not believe there was a tilt column for a four speed truck in 79 but I have since verified it did happen. Some of these options are just so rare that you never see them. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
- wildcard
I got mine off of E-Bay and figured it out by trial and error.
- Dragon
Just reminded me I should install mine Need a file but my Makita grinder makes a great file and cut off wheel.
Old Fords Rule
My Gallery
Spark test
My Gallery
Spark test
