i changed it to "our" nobody read my typing very close okay i make these mistakes all the timesideoilerfe wrote: Not true. Mine work without problems. Like mentioned above, replace the cam and you're good to go. B y the way, it is "our" not "are".
is there anyway to fix turn signal return?
- austin
Re: is there anyway to fix turn signal return?
I have the same problem with a floppy turn signal lever. for a quick fix, I am thinking of rubber bands to keep the lever centered until I can replace the plastic thing inside.
