I have heard this for years and I have also been pulling cables for years to quickly test for charging capability.cep62 wrote:m-mman wrote:With the engine running, pull a battery cable. If the charging system is working at all the engine will stay running.[/quote
Back in the days with generators this was standard practice.
This is not recommended with alternators ,it can cause damage.
I have found SOME Japanese cars that required a battery in the circuit in order for the charging system to function but never and old American car.
Yes the battery will act as a 'load' and would absorb peaks in charging voltage based on engine speed, belt slipage etc. But since the system is self energizing could somebody explain exactly what 'damage' might occur? and Why?
I understand that problems might arise to when trying to drive and add various loads to a charging system without a battery (Amp flow might exceed outout and voltage would drop to zero) but again what DAMAGE might happen?
The only thing I can imagine would be is an overwork situation and cause the output leads to get hot.
