Good afternoon Robert and Dustman_Stx, thanks for your excellent replies!
DuckRyder wrote:I think Canton may make the pan he heard about, I think I also heard something about it.
That is encouraging news Robert! I looked at all the FE pans on the Canton web site and didn't see it, and I tried to call them but they're already closed for the weekend. Perhaps I'll call on Monday!
DuckRyder wrote:In my opinion the pan you have is a decent pan, it isn't heavily baffled but it does have the later CJ style baffle which is much better at keeping the oil in the sump than the standard truck pan.
I think you're probably right! I'll have to chat with Tom about this again, since its capacity is five quarts, not four like Tom thought when he glanced at it. Maybe it will do the trick.
dustman_stx wrote:I found out the hard way about the oil pans. Had my 390 completely together, ready to drop in. Started lowering it in and realized there was no way it was gonna go. Passenger side of the oil pan was pushing the engine over- probably needed another inch or so of clearance. Had to pull the engine and figure out what to do next.
Dustman_Stx, thanks for filling me in on the story! Why does your story sound SO familiar to me?
Good to know that you discovered this fact through first hand experience. I'll be sure to let Tom know that the Canton T pan is very unlikely to fit (the only reason it still could fit is that I'm using the Autofab engine perches).
dustman_stx wrote:I ended up welding a baffle in my stock pan and now use 6 quarts total in the system as opposed to 5. From what I read this causes no problems as long as a windage tray is used to keep oil from sloshing onto the crank.
That sounds like an excellent custom solution! I'm still holding out hope that either my existing Milodon 30740 will work, or I'll be able to find a larger pan that will work too (for a modest price). The only other pan that I've heard will fit this application is the Dooley full-sump pan, but with all the odds and ends it requires, it adds up to over $700!
dustman_stx wrote:Also, note that the Edelbrocks flow very well from what I hear straight out of the box. A couple of hours just doing some cleaning up on the ports and polishing would be all that is required, if you even do that.
You're probably right here--I'm sure they do have great flow! I heard from Tom that the way their ports are shaped lends itself more to horsepower rather than torque though. I'm sure I've forgotten some points he mentioned, but I heard something about a big torque potential difference between ports depending on their height--there was a big difference between the absence of material around the top of the port, versus the absence of material around the bottom.
For some applications, he ports by removing material from the tops of the ports, and for other applications, he removes material from the bottom. In his opinion, the shape of the ports in the Edelbrock heads makes them great for horsepower-oriented engines in cars, while ported cast iron heads provide more torque for truck and heavy car applications. I heard from Tom that if Edelbrock heads were used instead of my ported, cast iron heads, the engine's torque rating would actually decrease!
dustman_stx wrote:Also,the Performer RPM is supposedly already matched to these heads, but I can't confirm that.
That makes sense, and that's a good point! I guess that's one of the benefits of going with the Edelbrock stuff--I'm sure it's excellent.
At this stage, with the cast iron head ported and intake port matching complete, the analysis is academic (but still very interesting and informative--I appreciate you bringing it up).
I don't mean to imply that any conclusions can be drawn from this, but it's interesting to note that Tom chose ported cast iron heads for his insanely powerful 1967 Mustang. From his
article on the Mustang, "C4AE-G heads off a stock 390 Galaxie. They have been filled, high ported, with 2.09 and 1.75 Ferrea valves. Heads flow 323 Intake and 220 exhaust."
Robert and Dustman_Stx, thank you again for your excellent, helpful replies!
Robroy
