radio problems
f1shermun
Re: radio problems
Post by f1shermun »
Ok. I found the condensor for the voltage regulator. How do you test the condensor?
michael69
Re: radio problems
Post by michael69 »
Just buy a new one their not but $3.00
Michael69
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
Re: radio problems
if the radio has a whine to it when the engine is reving and the condesor is hooked up and grounded then the condensor is bad. if it is static or another moaning type of sound the problem is in the radio.
f1shermun
Re: radio problems
Post by f1shermun »
I checked at the local parts store and they only have the condensors that go in the distributor. Is it the same thing? I know the connector is different. The condensor at the regulator has a pig tail connection.
Re: radio problems
i looke dat oriellys website. it shows a alternator condensor with part number g125. and the picture looks more like it goes inside the cap with the points. i then looked a tthe igniton and starting condensors and it also showed part number g125 and other part numbers as well. like g125p
michael69
Re: radio problems
Post by michael69 »
I got mine at advance auto as bad as I hate getting parts from them. :thup:
Michael69
f1shermun
Re: radio problems
Post by f1shermun »
if I replace the voltage regulator do I need to replace the condensor? I saw a post that said if I replace the voltage regulator with a solid state unit it would eliminate the need for a condensor at the regulator. is that correct? The regulator needs replaced. It is charging at 16volts
Re: radio problems
16 is too much. i read that the mechanical regulators can be adjusted to the voltages it outputs. i have no idea how to do it.
f1shermun
Re: radio problems
Post by f1shermun »
So, if I replace the old voltage regulator with a new unit, do I need to replace the condensor?
