Starting issue slowly and methodically driving me insane
knipdlo
Re: Starting issue slowly and methodically driving me insane
Post by knipdlo »
The regulator looks fine- nothing is cooked.. Could be the alt? I'll try removing the B+ and try starting it with B+ removed?
Thanks!
1969 F100 240/6 Auto 'New Lime' AKA 'The Baby Maker'
Dragon
Post by Dragon »
yep. If you had an ohm meter you could read starter wire to ground above 4 ohms is good. Alternator with B+ removed is the same. 4 ohms is a light bulb and they will burn out exposed to air but that is a good value to stop at less than 4 you know it is shorted.
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
71 Service manuals Volumes 1,2,3 and 4 So ask away. :)
My Gallery
Spark test
