Would a Hobart Autoarc 130 mig welder work for most body patches on the old truck. I found one on Craigs list for $300.00 For what it is I should be able to get it for a lot less but wnat to make sure it will suite my needs before I make an ofer.
Mig Welder
- 68FORDJBM
- 67mann
Re: Mig Welder
Just looked at one yesterday.... http://www.tractorsupply.com/mig-welder ... PricingCmd
So if the tank is include and you can get it under 300 and it's in good working shape
And to answer your Question....mig's with gas are 100% better welding sheet metal than the flux core wire models. Thin metal welding is touchy and practice is the only way to learn. I'm jumpin in late here,but it sounds like ya have welding skills on other machines....so your that much ahead of the game
- HIO Silver
Re: Mig Welder
Give it time, you'll eventually want a bigger welder!68FORDJBM wrote: Thanks for the tip though. I'm not sure I want to spend $1100 on a welder. Looking back do you think you could have gotten away with just a 110 and paid less. The welder that Mancar1 picked out is less than $400.00
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
