T5 Swap?
SDFarmKid
Re: T5 Swap?
Post by SDFarmKid »
Do you mean TOD? From what ive found researching the SROD is a different transmission used before they introduced the TOD in 84.......
Mine - 1969 Ford F100 ShortBox
Original: 360, T18, Dana 60, Custom Cab, Red
Now: 302, M5R2, Front Disc, Black Leather Interior, Grabber Blue
Dads - 1969 F100 Stepside
Original: 390, c6, Custom Cab, White
Plans: Drive it and....?
Chandler
Nitekruizer
Re: T5 Swap?
Post by Nitekruizer »
Both the S.R.O.D. (Single Rail Over Drive) and the T.O.D. are ALUMINUM cased transmissions that were loosely based on the old Top Loader design of the '60's but were nowhere near as strong. Both of these trannies have an OD ratio of something like .80:1. The S.R.O.D. was installed in F-series pickups from 1979-83. It has internal linkage but has a weird little shift "turret" attached to it just behind the main case. The TOD (code RTS) trannies replaced the SROD in '84. The TOD has the shifter coming out of the top of the tranny just like a T-18 shifter. The SROD's are a light duty trans, maybe good for a 6 cyl or a stock 302 probably nothing more. Although I think Ford used them behind sixes, 302's and 351W's. I don't know much about how strong the TOD is but I have seen one installed behind a 400. It is an aluminum case tranny and to my knowledge the largest engines Ford ever put in front of it was the 351W. I hope this helps. :)
Hawkrod
Re: T5 Swap?
Post by Hawkrod »
SDFarmKid wrote:Do you mean TOD? From what ive found researching the SROD is a different transmission used before they introduced the TOD in 84.......
Yup, your right, I was typing faster than I was thinking, thanks for the correction. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
SDFarmKid
Re: T5 Swap?
Post by SDFarmKid »
Thanks i agree that it is nowhere near as strong as a t18 or an actual toploader, but this truck will be used mostly as a driver, the only thing it might ever have a chance at towing is a homecoming float. :D So would this have the same input shaft spline count and length as a t18? Thanks everybody for the help :fr:
Chandler
Nitekruizer
Re: T5 Swap?
AFAIK both the SROD and TOD have a 10 spline, 1 1/16" input shaft but it seems to me that I vaguely remember that the input shafts are longer than the input shafts of Top Loaders and other trannies like T-85N's and T-18's. :)
Hawkrod
Re: T5 Swap?
Post by Hawkrod »
Nitekruizer wrote:AFAIK both the SROD and TOD have a 10 spline, 1 1/16" input shaft but it seems to me that I vaguely remember that the input shafts are longer than the input shafts of Top Loaders and other trannies like T-85N's and T-18's. :)
Input shafts are standard length and are the same as most Fords 3 speeds from the 50's-80's and so they are the same as top loaders and T85's but T18's can be longer or shorter depending on years. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
SDFarmKid
Re: T5 Swap?
Post by SDFarmKid »
OK..well i got just have to go get it and if i have to i can make a spacer plate if its to long Thanks everybody for the help! :D :fr:
Chandler
