NOS Ford F-100-250-350 truck alternator harness SOLD OUT !!!
Re: NOS Ford F-100-250-350 truck Alternator harness (SOLD 1)
Ebay item # 390858074143 NOS Ford in box C7TZ-2A635-F Fits Right rear on 4WD trucks Buy it now $63.96 plus S & H $10.96 and there in Sherwood Oregon and the 4x4 one does have that rubber grommet with that angle your looking for ?? and iam sure you can use this brake cable on your 1972 Ford F250 4x2 Truck and i found the correct one for your 1972 ford truck on Ebay item number # 161406911972 NOS Ford in box DOTZ-2A635-A Rear (RH) Side Buy it now for $25.00 S&H $9.00 there from Donaldson GA and this does not have that Rubber angle grommet boot that your looking for ?? and he has the left side too Ebay item # 151358888773 DOTZ-2A635-G (LH) Side Buy it now for $25.00 S&H $9.00 and you can look at the pics on ebay and see if this will work for you and hope this helps you out Thank you Kurt
1970-72 Ford F250 4x2 Rear Right side Brake Cable ford part number # D0TZ-2A635-G
1970-72 Ford F250 4x2 Rear Left side Brake Cable ford part number # D0TZ-2A635-A
1967-72 Ford F250 4x4 Rear Right side Brake Cable ford part number # C7TZ-2A635-F Has rubber Angle grey grommet boot
1967-72 Ford F250 4x4 Rear Left side Brake Cable ford part number # C7TZ-2A635-E Has rubber Angle grey grommet boot
Re: NOS Ford F-100-250-350 truck alternator harness SOLD OUT !!!
Need under dash harness 68 F-250
I can get you a good used one.ridgegregory wrote:Need under dash harness 68 F-250
1967 F-100 4x4 custom cab.
