Borg Warner overdrive
fivo2fst4u
Re: Borg Warner overdrive
Post by fivo2fst4u »
ScottT80 wrote:You have any pictures of the setup? Where are you located at?
Hi, I can get a few, I'm in Eustis,Fl. About 35 miles north of Orlando, just about in the Center of Florida (east to west wise) It has the two wire solenoid, and single wire governor. I have the wiring all sorted, everything is functioning as it should, however, it will not drop into overdrive, I think the blocker ring may be jammed? I pushed on the pawl with a phillips screwdriver, it went in about 1/8", but did not return, and I pushed it again, but it was like pushing against a solid object.
