Grant Steering Wheel
- trukcrazy
re: Grant Steering Wheel
Hey Joe, if I remember correctly, there are either 3 or 4 different kits for our bodystyle trucks. One for 67, one for 68, one for 69 and one for 70-72 or some combination like that. I know my kit for my 67 didn't really work right on my 68. Minor differences, but still differences. I would check on the Grant site to be sure.
John, #424
1967 F250 crewcab x 2.
2008 Challenger SRT8
Good Luck with self canceling turn signal. I had a 15" Grant for years and had off & on several times trying to make self canceling turn signal work, either pin was too long and would rub and knock itself out or too short and wouldn't work, which is way I ended up leaving it, with an extra loud flasher. Thankfully when I put in new tilt column and new wheel (with dreaded GM adapter kit) everything works fine.
Trevor Rush
- Joe Kriston
Thanks,John and Keith...What do you think that adapter would retail for...so I make sure I bid a lot less?
Cacwby is the cancelling pawl part of the adapter kit or do you use the one already in your column?
- trukcrazy
Joe, I believe around 20.00 in the catalogs and parts houses. I didn't have the self-cancelling problem with mine in either truck. Maybe there are slight differences in the manufacturing?Good luck, John.
John, #424
Re: re: Grant Steering Wheel
I believe you re-use, and for all I know I may have been the only one to ever have a problem.Joe Kriston wrote:Thanks,John and Keith...What do you think that adapter would retail for...so I make sure I bid a lot less?
Trevor Rush
- mk
I just bought a kit last week to put a wood rim wheel on the 79 tilt column I plan to install in my 68. It was #3249. Checked out the Grant site tonight and here's what I found:
67- #3294
68- #3285
69- #3249
70 to 77- #3285
78 to 91- #3249 tilt or plain
The instructions do make mention of that extension on the end of the columns too, Keith. "It will be necessary to hacksaw this off for proper horn operation".
mike
67- #3294
68- #3285
69- #3249
70 to 77- #3285
mike
- Joe Kriston
Geez,you guys are helpful...Thanks for the part numbers Mike...Anybody know why the 69 is different?...I'm going to go ahead and buy Jor's...But I'm not too crazy about sawing the tip of the steering shaft off...If I did,would I ever be able to go back to an original wheel?....The previous owner also installed a dash buttoned 'a-ooh-ga' horn which I'm going to keep on there for sentimental reasons,....I suppose I could just wire the a-ooh-gah horn switch to the regular horn if I don't want to do any hacksawin'....Or mebbe get a spare shaft at a junkyard...Are those hard to change?
- jor
Hey, everybody, all I know is both the original wheel and the Grant work fine on my 68 and nothing has been sawed or chopped.
jor
jor
- Joe Kriston
Well,when I get Jor's and install the thing,I'll make sure I borrow somebody's Polaroid Swinger and let you all learn from my trials and tribulations...
- mrung0wa
JOhn's right there are several different kits for our years.
I ended up buying about 4 different ones and using parts from each one.
Sometimes my turning indicator cam functions, sometimes it no work?
I also installed the Handy Dandy Quick Grant Disconnect to my wheel and I love it!
I recommend it to all my brothers out there in TV land!
Ain't no one gonna try and take my Jethro from me...Not even old man fire!
Lawrence
Lawrence
http://www.fordification.com/galleries/ ... ?pos=-2746
FOR SALE: 64 Galaxie 390HiPo C6 (Project Car)
SOLD! 69 F100 Contractor SPECIAL 300 I6 "Jethro"
01 BMW 325i 4DR E46(Wife's car)
03 EXPEDITION XLT FX4(2WD/AWD/4WD) 5.4L K&N FipK
"I beat my head against the wall, Because it feels good when I stop."
Quick Disconnect????Tell us more..........
